paddlenbike
I ended up with the 7" Samsung Galaxy Tab 2. They are $209 and feature an SD card slot that allows me to offline cache 64GB of maps for use with Backcountry Navigator.
How do you like it so far?
Paddlenbike, can you give us an idea how much memory the Backcountry Navigator cached maps take up? Are the maps selected by region, by square miles?
I stored highly detailed topo maps for the Inside Passage of Canada, an area about 200 miles by 150 miles and it took 6 GB. Here is a screenshot as we were passing the Canadian border.
The 24k topo maps for a 50 mile square area in the Sierras for 4wheeling was about 1.5 GB. It is completely dependent upon the size area you choose and the maximum resolution of the maps you download. In BCN, you click an icon and it lets you select an area or areas for download. You basically drag a box around the geographical area you need, then you select the maximum zoom level you see yourself needing. I just choose the maximum zoom level of 15 because I have plenty of storage space on the SD card for it. I am coming from Memory Map, where I had to download each 24k quad map separately...BCN makes this process so much easier.
Have you tried TWONAV?
I use it and it´s very simple
How do you like the internal GPS. I contemplated getting one but was turned off by the FRY's salesman. He said it really wasn't that good. Have you run into any issues with accuracy? What happens if you leave your preloaded map area? Will it self update? Thanks
It so happens, I just won a Tab 2 7.0 in a chili cookoff!
I am totally unfamiliar with GPS navigation and this is my first Android device as well, so these may be dumb questions:
The Backcountry Navigator seems interesting. Are the maps included with the $9.99 app price? I find some mention of additional map content for purchase. Just a bit unfamiliar with the concept.
Thanks in advance.
Thanks for the tip, I've been looking at the Galaxy Tab because of the smaller form factory than my iPad. I'm defiantly picking one up now. Whats the cost for downloading maps for BCN?
