Jeff@QuadShop
Has anyone seen a SAS done that gives very little lift? I'd love to have SAS but don't want to be way up in the air (2" lift max). I'd like to do it using stock 84-85 springs in the stock spring under setup.
86-94 toyota
TONS of info out there on this. Pirate4x4, Marlin, Yotatech are your search button friends.
check this thread for starters: http://www.pirate4x4.com/forum/showthread.php?t=674078
your running an IFS frame, like me, and it has a flatter front section than the SA frames which have an arched area over the front axle. This may cause you a problem when arranging your steering link off your box, some run flat arms to help. You should also consider a longer spring than the Toyota oem SA spring to give a better ride and flex.
post up some pics once you get going with that grinder
SA Toyota trucks were all spring over......... Or I thought they were.
