Scalable aux. electrical solar circuit
mitchkman
Hi,
I'd like to add dual battery and solar setup to my truck (2011 Nissan Frontier Pro-4X). I'm going slightly over budget with my build already so I need something small to start with, yet easily extendable for bigger needs.
Here are my energy requirements:
- Laptop: 240wH/day (4H usage * 60w)
- 2 cell phones: 18wH/day (2 * 9 w per charge, one charge per day)
- Diesel heater (8kw output) : 350wH/day 240wH/day (10H usage * 3.5w 24w on high temperature)
Total requirements: 608 wH per day / 51 aH per day 498 wH per day / 43.6 aH
As input I plan:
- 100w 200w solar panels, 660wH/day 500wH/day (60% 50% avg. output * 11 5 sun hours * 100w 200w)
- 130 amp alternator to jump in when needed
As for equipment, I plan on using:
- 12v DC/DC charger, acts as isolator as well: https://www.renogy.com/dcc30s-12v-30a-dual-input-dc-dc-on-board-battery-charger-with-mppt/
- 300w inverter https://www.amazon.com/BESTEK-300W-...1&keywords=car+inverter&qid=1605834283&sr=8-5
- Solar panels: https://www.amazon.com/Renogy-Monoc...ywords=100w+solar+panel&qid=1605834499&sr=8-1
- 100aH battery: https://www.amazon.com/Rechargeable-Battery-Trolling-Wheelchair-Universal/dp/B07ZN12CKD/ref=sr_1_1_sspa?crid=3DDEJCXJJIZWR&dchild=1&keywords=100ah+battery+12v+deep+cycle&qid=1605834526&sprefix=100+aH+,aps,215&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFWSjRaVjc5V0VLU0MmZW5jcnlwdGVkSWQ9QTAyNjE4MTQxRjNUQkpNVjJRUVFCJmVuY3J5cHRlZEFkSWQ9QTAwMDA5MzkxT0M5WkFQUVBYOEpEJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
- Diesel heater: https://www.amazon.com/Fiberfly-Muf...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Questions:
1. Do the calculations make sense?
2. Can I easily add another solar panel in parallel and it'll just work?
3. Can I easily add another battery in parallel (assuming the same exact battery) and it'll just work?
Thank you!!
Probably won't get 11 hours of good sun in the winter when you will need the heater. Maybe 4 or 5 @ 50%. As an example, right now, 10am central and 43 degrees north latitude, clear day, I'm pulling a whopping 1.25 amps (about 21 watts) on a 50W Renogy panel that I'm doing some testing on. Panel is rated for 2.84 amps optimum.
Yes you can just parallel up the panels.
Thank you all!
Your calculation for heater seems faulty ”Diesel heater: 350wH/day (10H usage * 3.5w on high temperature)”
Yeah, 3.5 was the amps on max temperature, not wattage. Also, I changed my calculation that I don't need to run the heater on max temperature all night - let's just say it draws 2 amps.
With the Winter output, I guess I'd need a 200W solar panel to be even without starting the truck to charge.
Let me know if my changes above looks better.
empireoverlandza
