scanguage2 or other, also air fuel mod chips and such reviews, likes dislikes
QCAuto
whats everyone running for measuring or modifying ecm fuel etc on the 7.3 diesels?
heres a review someone wrote on the interweb, only one so looking for more
\thell me what you have and why, or which you plan to run, thx
REVIEW:
Scanguage uses the maf sensor to calculate economy which is useless on a diesel
I had one and if you own a diesel fuel economy won't work. Scanguage uses the maf sensor to calculate economy which is useless on a diesel.
Mwilliamshs
ScanGauge2 works fine for mpg with diesel. It calculates mileage with VSS, injector PW, etc. I like mine and use it a lot on a 2002 CC DRW PSD.
Mwilliamshs
1995 is a weird year for OBD, especially diesels since emissions standards were different for heavier rigs.
1994 were all OBD1 so no Scangauge compatibility
1996 were all OBD2 so full Scangauge compatibility
1995 is kinda hit-n-miss with being the transition year
ert01
Scan gauge II works for my 02 7.3 but the mileage seems to get a bit wonky when I play with my TS chip and it takes a tank or two of running on the same chip setting for it to get accurate readings again.
naterry
13 Cheeseburgers
The SG2 is reading some data my 96 but I had to force it with the PWM option. I'm missing the oil data. Does anyone know about special codes on these?
djbonsu
I have used the following x-gauge codes (these arent listed on the website) for the 7.3 PSD below with success. I believe I had to reconfigure one of them but I cant remember which one. If one of the doesnt work, let me know and Ill check my SG II and update it here. There are more on the scan gauge website that work as well. Its a bit tedious to program it but once done its worth it.
These are the code that I have working on mine.
Coolant Temp:
TXD: C410F1221139
RXF: 046205110639
RXD Engine: 3008
MTH: 00010002007F
NAM: ect
The value displayed by this XGauge is only valid after the coolant temperature gets above
127* F. Before the engine is warmed up the displayed value will go up to 255 about double
actual then starts over at 127. This is becasue this PID is scaled for two different ranges. It
works good on my 2000 7.3 and seems to be accurate. This has been a long sought after
XGauge for the 7.3 crowd for quite some time.
Glow Plug Percent:
TXD: C410F1221430
RXF: 046205140630
RXD: 3008
MTH: 0F5127100000
NAM: gp%
This is a good way to see how long your glow plugs are staying on. They will stay on for
quite a while after the engine is running and the glow plug (wait to start) light has gone out.
Engine Oil Temp:
TXD: C410F1221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFFD8
NAM: EOT
IPR Duty Cycle:
TXD: C410F1221434
RXF: 046205140634
RXD: 3008
MTH: 006400FF0000
NAM: IPR
Injection Control Pressure:
TXD: C410F1221446
RXF: 046205140646
RXD: 3010
MTH: 003800640000
NAM: ICP
Exhuast Back Pressure:
TXD: C410F1221445
RXF: 046205140645
RXD: 3010
MTH: 016C03E80000
NAM: EBP
Transmission Fluid Temp: (This one is already documented in their XGauge Ford PWM
section)
TXD: C410F1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
naterry
13 Cheeseburgers
Coolant Temp:
TXD: C410F1221139
RXF: 046205110639
RXD Engine: 3008
MTH: 00010002007F
NAM: ect
Glow Plug Percent:
TXD: C410F1221430
RXF: 046205140630
RXD: 3008
MTH: 0F5127100000
NAM: gp%
Engine Oil Temp:
TXD: C410F1221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFFD8
NAM: EOT
IPR Duty Cycle:
TXD: C410F1221434
RXF: 046205140634
RXD: 3008
MTH: 006400FF0000
NAM: IPR
TXD: C410F1221446
RXF: 046205140646
RXD: 3010
MTH: 003800640000
NAM: ICP
TXD: C410F1221445
RXF: 046205140645
RXD: 3010
MTH: 016C03E80000
NAM: EBP
section)
TXD: C410F1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Excellent! Thank you for this.
Mcoleman
