Scope for a .22 LR ???
Schattenjager
I am building up my very first rifle - a 28 year old Ruger 10/22. It's getting a Volquartsen barrel and trigger group along with a picatinny rail. It has been years since I shot a .22 much, but with the threats against gun ownership and ammo availability, I thought I would build a fun 'shooter' that is reliable, fun, and cheap to shoot.
Any of you have experience with rim fire scopes? I doubt I will shoot more than 150 yards, but Volquartsen says the combo they put together consistently shoots 3" groups at 300 yards. That must be on the moon - I forgot to ask.
Any ideas are welcome!
I have a Leupold Scope..........on my Remington 700 Heavy Barrel........ 22.250 .
http://www.leupold.com/
With that........I can hit a poor little woodchuck at 400+ Yards.........in da head in a cross wind!
4,000 feet per second! Shoots Flat........baby!
That's my choice! See if they have one!
I've hit Ojai Valley Gun Club's hanging 3" thick Ram at 278 yards with a .22 LR. Not once, but repeatedly with a 1920's era Stevens Favorite fitted with a Marbles Model 92 tang sight and a Lyman 17A. It took a while to walk them up there and I was aiming for nearly the top of the hill behind it. ;)
I'll second the Leupold recommendation. They offer a rimfire focused scope.... well they used to. They now offer three different RF scopes. And I know that you can have their custom shop set up any or nearly any other scope in their line for use on a rimfire. The difference is the fixed focal plane and the parallax that develops from shooting at other distances.
IME cheap scopes change point of impact with change of power (if so equipped) and have poor light gathering ability. If you could find a used Weaver K4 or K6 it would likely be the same price as an inferior new cheapie and be a much better scope even factoring in the parallax issue (which isn't that big of a deal).
Weaver M34 fixed 4X that I got used is what I have on my 10/22. It's a pretty low model and I think it might actually be an air rifle scope. Anyway, I like iron sights better. Guess it depends on use, mine just makes holes in paper. I just don't see the usefulness of anything beyond 4X on a 10/22. I happen to fully agree on fixed focal length. If you're getting a zoom scope, don't go cheap (should have said that). Same as camera optics, cheap zooms give up too much.
ntsqd, you're a better aim than me. I couldn't hit the range 200 yard target reliably, although I'm running a stock 18-1/2" barrel and a longer barrel (the Stevens has about 21" barrel, right, or is one of the really long barrels, 25" or whatever?) might make the difference.
If I were to do a 10/22 right now it would shoot arrows....really.
http://www.swivelmachine.com/html/rimfire.htm
Don, I had a Volquartsen carbon barrel with a cantalever scope mount and there was no way it would group at 300 yards. Not even bolted down! The gun was fun but expensive for a 50 yard plinker. The real problem with 22's was them ammo. I ended up shooting sub sonic Eleys that worked great! Good luck and post pics!!!
20 years ago (wow time flies) I bought a 1.75 to 5 power scope for my Ruger 10/22 that cost as much as the rifle did. Don't buy crap from Wally World or whatever if you are interested in accuracy and repeatability.A rimfire rifle can be accurate out to 100 metres with the right setup so settle for that. The only work I had done was to hone the trigger group and buy good ammo (for years I could get the good Russian stuff but now I settle for the European stuff and if I am desperate I will shoot Gold Medal from Federal.Rimfires are fussy about their ammo so when you find something that works buy the case (5000 rounds?) if you can.
Get a Shepherd P22LR.
http://www.accessmylibrary.com/coms2/summary_0286-9576580_ITM
COPYRIGHT 2005 Publishers' Development Corporation
When the little Ruger .22 hit the I" paster at 100 yards, no one even noticed. When chickens on the silhouette range at 200 meters began rattling, a few eyebrows began to rise. When the tiny .22 slugs began pinging the metal javelina at 300 meters like Oklahoma hail in April, the doubting Thomases drifted over to see how I was doing it.
And if I told you that a few minutes later I was consistently hitting the turkey silhouette at 410 yards, you probably wouldn't believe me. However, when the wind is still, you can indeed fire up to 400 yards accurately with a .22 rimfire. The secret at the time was a trajectory-compensating scope that's been floating around for a number of years--the Shepherd.
Range Finding
I have never been very impressed with the various range-finding and trajectory compensating scopes commonly available. The designs I have tested seemed to have been engineered around a mythical animal that would stand broadside for an indefinite period while one bracketed the critter with the horizontal stadia or cranked in the elevation with a moveable trajectory cam. Not so with the Shepherd.
Dan Shepherd, the scope's designer, had a different idea. In simple terms, the Shepherd scope line is designed around various commonly used rifle trajectories--basically the .22 rimfire, the .30-06 class of cartridges and the high velocity numbers.
When looking through the scope, one sees a vertical string of circles with various range designations noted beside them extending from the center of the reticle to the six o'clock position. Shepherd's .22 scope, Model 310-P22LR, incorporates a series of 9" circles calibrated in 50-yard increments from 50 to 500 yards. Because the reticle is in the first focal plane, the diameters of the circles are a constant 9" at all ranges and powers.
A prairie dog stands about 9" tall. The depth of a coyote from shoulder to brisket is 9" to 10". Beginning to get the idea?
Fast And Accurate
After you have zeroed the scope and know the approximate size of the game being pursued, you match the height or depth of the critter in an appropriate circle and pull the trigger. It's that fast and that accurate a system.
There is a great deal of sophistication built into the Shepherd scope adjustments so that one can adjust the aiming reticle for windage or elevation and return it to zero. This is a useful adjustment for static-type hunting, such as targets or prairie dogs. I'm not advocating that one should be shooting at a prairie dog at 400 yards or even at 200 yards with a .22 RF, but a scope like the Shepherd is fun to play with and certainly brings out all the ballistics a rimfire has to offer.
When I look at the scopes on some of my .22s, they are a diverse lot. The first scope I ever bought was a little Bushnell Banner 4X subsequently mounted on a Winchester Model 69. The Bushnell cost $9.95. It's been mounted on a Feinwerkbau air rifle since 1971. It is still clear. The adjustment turrets are still precise. What more could one ask for?
Another of the little 3/4" tube .22 scopes still rides my old Marlin M39. It's an ancient Ted Williams "Signature" 4X scope bought from Sears for $11.95. It, too, still offers rock-solid performance over rimfire ranges.
A recent .22 rimfire scope I bought is a Bushnell Sportsman 3-9x32 with target-style windage and elevation dials and an adjustable objective for parallax settings from 0 to infinity in yards. It's mounted on a super accurate Anschutz Model 54 Sporter, and it's proved to be a dilly since I've recorded the elevation adjustments for ranges from 50 to 150 yards.
Don't overlook the possibility of mounting a true big-game scope on your rimfire, particularly the compact and straight-tube models that are proportional in size to rimfire rifles. My old Steyr Mannlicher carries a Leopold 3X, and with its wide field-of-view, it is a superb scope for bouncing bunnies.
Since most rimfire work is at distances less than 100 yards, manufactures typically set-up their rimfire scopes to be parallax free at 50 yards. Having an adjustable objective to fine tune for parallax and variable power selection are real pluses in .22 scopes, since we're usually shooting at very small targets and often well out to 100 yards and beyond.
Recently, scope manufactures have introduced a variety of high-end .22 scopes. I've hunted quite a bit with Kahles 2-7x36 American Hunter rimfire scope mounted on a Remington Model 504. It is optically outstanding and well worth the price tag if you're more than a casual plinker.
Within the last year, there has been an outpouring of scopes designed around the ballistics of the. 17 HMR and. 17 Mach 2. BSA offers their Sweet 17 and Mach 2 models featuring drop-compensating elevation drums to track the trajectory of these wee rounds precisely from 100 to 300 yards.
Among the most sophisticated of the new rimfire scope designs is the Sako Quad Scope from Burris permitting the user to instantly adjust the scope for the ballistics of either the .17 Mach 2, .17 HMR, .22 LR, or .22 Mag. That's quite a scope full.
The best part of the story is that scope makers are paying more attention today to the rimfire market than ever before. In optics, you may pay for what you get, but even the low-end .22 scopes can give you years of plinking pleasure.
BURRIS
(970) 356-1670
WWW.BURRISOPTICS.COM
BSA
(954) 581-2144
WWW.BSAOPTICS.COM
BUSHNELL
(800) 221-9035
WWW.BUSHNELL.COM
KAHLES
(866) 606-8779
WWW.KAHLESOPTIK.COM
LEUPOLD
(503) 526-1400
WWW.LEUPOLD.COM
SHEPHERD ENTERPRISES
(402) 779-2424
WWW.SHEPARDSCOPES.COM
WEAVER
(800) 285-0689
WWW.WEAVEROPTICS.COM
Thanks Harry!
I had seen that article about the 300 METER shot but was afraid to mention it since I could not reference the source. The Shepherd is a compelling, spendy option. But how much fun would THAT be??? I really appreciate the time you took to compile the info - I'll be using it Monday AM!
I was going to go for a couple more guns, but the scuttle butt is that ammo is going to be banned / taxed 500% etc. before guns, so I am stocking up on .223, .10mm (reloading) 12ga shot and slugs, and I just got a 5K round case of .22 LR ball. I might get another 5K of hollow point, but first I need a ton more .223 Gun and ammo sales are through the roof because of fear. Wasn't it Palpatine that relied on fear? Hmmmm.... maybe Sith are leading the way! Anyway - I am sure to have the most expensive / least valuable .22 LR in the remaining free world.
:elkgrin:
20"-21" sounds about right for the Steven's barrel length. The Marble's M92 tang sight puts the rear sight back another couple of inches from the breach. With a .22 LR it's all about the sights and the sight radius AFAIC.
Good iron sights, those not found on very many rifles any more, are worth quite a bit in accuracy. I've never thought that the so-called "Buckhorn" or v-notch type of rear sight (ala' the OEM 10/22 sights) were worth a dang. I modified a Rem 740 iron sight base to fit the side of my 10/22's receiver and have an old Redfield target peepsight with matching globe front on my 10/22. Last I looked the sights were worth more than the rifle.
Barrel is a generic SS bull barrel, action job is all me. In our normal accuracy contest of knocking over stood-up shotgun hulls (shoot until you fail to knock one over, then the next guy/gal shoots) that rifle has been deemed forbidden in anyone's hands.
Scope recommendations. Look for one with an adjustable objective (AO). It will help with the parallax. Most scopes designed for high power rifles that do not have AO have a fixed parallax for I believe 150 yards. If you get an AO, you can be more accurate at closer ranges. If you need more info on this try Google or pm me.
That being said, I have a Leupold 2-7x VXII on my CZ .22 mag and my old Ranger .22 lr. They seem to work well enough for my old eyes and fit the guns better.
I tried my B&L 2.5-10 with AO once on the .22 lr and it improved my accuracy at 100 yds. It just looked way too large. Also I had a 10-22 set up for target shooting with a Burris 6-18x with AO. It was a tack driver. Unfortunately I sold it to try something else. Just the engineer in me I guess.
Some outdoor writer in Predator Xtreme wrote about using an air gun scope. They usually have AOs. Also they are designed more rugged in both forward and reverse directions for spring piston guns.
Personally I believe you should spend at least as much on the scope of a rifle as the rifle. If you cannot see what you are shooting, you shouldn't be shooting.
Just my $.02
Bumper for another 10/22 owner!
For a fancy 10/22 like you are building, get a nice scope. A Leupold 3 x 9 would be an excellent choice. It's not like you're building a "plinker". The scope will likely cost as much as the rest of the rifle.
If you're an average 22 shooter that just wants to blast some ammo down range and not spend much $$, then a cheaper scope fills the bill perfectly.
When I got my son a 10/22 4 years ago, I knew his interest was going to be targets, cans and general shooting when we camp out. There used to be a website called "cheap rifle scopes" or something like that, and we bought the highest rated scope under $100. It's a 4x Simmons AO or something like that and it's been perfect. It's cheap enough we have not given it any special care and it will hit cans at 100 yards without any issues. We did use a nice set of rings, not the ones that came with the scope. After shooting thousands of rounds, we have settled on CCI minimags, and 50 yard sighting as the best all around compromise of accuracy, cheapness and general fun.
Someone else mentioned that 10/22s are particular about ammo. I could not agree more. The 10/22 won't even cycle the really cheap stuff reliably. We've had good luck with the mid priced Remington and CCI, so that's all we shoot. The CCI Stingers were the best, but cost more than the CCI minimags. Bottom line-stay away from the Federal $20 for 500 bulk boxes at Ammodepot.
Rimfirecentral.com is the ih8mud of the .22 world. It's amazingly comprehensive, and you should check it out.
2eleven
