Selling my expedition camper
Trimmer09
2023 Expedition Overland Off Grid Camper. 30k OBO. Will consider offers and trades for 20'x72" (or similar sized) center or side console, Jon boat, of equal value or cash to make up agreed difference. I do not use this outfit as much as it deserves.
Some details:
Nebraska Title and VIN
Heavy duty reinforced frame
#3650lb torsion axle with brakes
15x6 steel wheel black with Yokahama Geolander MT tires
2" rear reinforced receiver
Reinforced Jeep style fenders
Frame is epoxy sealed and Rhino lined.
Floor is marine grade 5/8 plywood with abs plastic fused to bottom side for rock and water protection. Glued and fastened to Frame.
Front Modular Custom Utility Rack (not shown in all photos) added May 2024
1.5" closed cell insulation 1/2" plywood top
Walls are hybrid 1.5" mild steel skeleton 16" O.C. and 1.5" clear #1 pine with 1.5" closed cell pink insulation
All marine grade wiring grommeted through steel.
12V interior LED lighting with dimmer
12V power charging ports
110 interior outlets in cabin and galley
Removable LED flood lights at rear roof with 12v SAE plugs and (2) courtesy lights above entry doors.
Exterior and interior covering is MaxMetal aluminum ACM panel
42" tall entry doors
Fridge slide with fridge
Insta hot shower (awesome, btw)
2000 Watt PCL1 Renogy Inverter/Charger
400 ah Redodo batteries
200 watt Bouge RV bifacial solar panel
21 gallon water tank. Encased in aluminum heated Frame box, with in-cabin access under bed
Oak cabinetry
6" trifold mattress
24" Flatscreen tv
LH and RH closet above pass-through in cabin as well as cabinets above sleeping area.
Diesel heater with ducts and controller in-cabin and externally mounted tank inside a sealed vented side box. All hoses mounted in rigid conduit
Maxxair Maxx fan Deluxe with remote
Custom all aluminum roof rack
designed by Legacy Craft Co. 60x96"
Rhino 8' awning drivers side. Overland Vehicle Systems 7' awning passenger side. Rhino comes with end wall and 2 side walls.
Overland Vehicle Systems roof top tent. Bushveld 2 with Custom Annex
room for increased height of vehicle.
Rhino Rack Collapsable ladder with mounting brackets
Exterior 12v accessory ports passenger rear for charging and power
Roof 12 Volt accessory port for tent users. This port uses a SAE plug that can use many adapters, waterproof.
Box length 11' 9"
Box width 64"
Trailer width 7'
Overall length 15' 8"
Ground clearance 14"
Interior height 51"
Axle weight #3650
Unloaded weight #2500
So much more. If you want to be completely off grid this is it. This rig will run many days on batteries alone. The solar panel is efficient and charges fast. The whole system plugged into 110 will charge in 6 hours. Immaculate condition, no corners cut, come see for yourself. Truly one of a kind.
  • Like
Reactions: plh
Houie
