Side Mount Battery Terminals
I need to find a couple of side mount battery terminals. The only ones I've found are a clamping style like shown below. I need two side mount terminals but with a single bolt in the middle rather than the clamp. My cables already have ends on them.
Maximus Ram
So do you want to mount the cable to the side like they mount on top..if so, then what about these
[ame="http://www.amazon.com/Pico-0893PT-Battery-Adapter-Package/dp/B00030CPC8"]Amazon.com: Pico 0893PT Side Mount Battery to Post Adapter 1 Set per Package: Automotive[/ame]
or are you wanting to attach accessories...then maybe somthing like this
http://cgi.ebay.com/BATTERY-TERMINA...019?pt=LH_DefaultDomain_0&hash=item53d7f675cb
I have something similar to these for my accessories on my DH Platinum.
Never seen any with a single bolt.
Closest I could find is about 3/4 of the way down the link here
http://crimpsupply.com/battery-terminals-copper-lugs
Apparently I'm looking for something that may not exist. I've attached it temporarily with the connector pictured with one of the two bolts through the end of the wire. It looks odd but gets the job done. If I can't find one, I guess I'll have to find someone to do some minor mod work.
I think I figured out the problem. Basically, there is no need for what I'm looking for normally because of you have a looped end to your cable, you just connect it directly, without another connector. I have an OEM fuse block at the end of the battery cable so when I switched batteries, it doesn't quite reach the terminal. I'm trying to find a solution but what I want, doesn't have a purpose in other applications.
Mwilliamshs
Yes if what you want is to add an additional cable directly to the battery post.
Safer to use a junction block and can work out cheaper and with less voltage-drop that way too since cable lengths can be equalized and runs made shorter overall and connections placed more conveniently.
Houie
