Trailwerx
I came up with this solar mount for my '96 F350 utility body camper. I'm in Alaska so roof-top mounts aren't so great with our low sun angles and I sometimes carry a canoe on the roof rack. I used Quick Fist rubber mounts which provide a bit of suspension for the panel on our rough roads. I used extendable paint roller extension poles (~ $15 each at Lowe's) for the adjustable supports to hold a 160 watt panel at the desired angle and to prevent the wind from catching the panel and possibly flipping it over onto the roof. I carry three different length poles which allow any tilt angle from flat against the wall to horizontal and it also extends past horizontal in cases where I have to park with the sun on the other side of the truck. I keep it in the vertical position when driving and tilt it up when I park. Works really well so far and I have room for another panel next to the existing one if I need more amperage.
