andrew61987
When I got my 2008 Tacoma last year (my first 4x4, I'm somewhat new to all this) it had a new set of Dakota Definity 245/75/R16 A/T tires, load range E which I believe to be the heaviest duty tire in terms of load range you can reasonably put on this truck. I was suspect of the tire brand because I had never heard of it, but they were new so I run them. 20k on them now.
Over the weekend I punctured a sidewall on my front left on a rough and narrow 4WD-only route up in Shasta-Trinity NF. Not huge rocks, small rocks and lots of fallen deadwood. I don't know how it happened. I believe it was probably during a tight 5 point turn around after coming across a huge fallen tree blocking the trail, I heard the hissing about 5-10 minutes after.
I was not aired down because I don't currently have a way to air up.
It's obviously my screw up for abusing the tires and still learning. My question is how big a factor did my air pressure and tire quality play? I was under the impression that these tires were pretty tough (10 ply) and I'm surprised I blew one doing what I did. Are there tires out there that have notably tougher sidewalls more suited to my uses or do I just need to chill out and be more careful? Note that I use it to commute about 180 miles a week when not exploring off road but I'm not against losing some road comfort for wilderness peace of mind.
