I'm seriously irritated right now. I used two whole tubes of Sika 715 to seal two Fantastic fans and a couple seams on the new roof of my Alaskan rebuild. It's been at least 48 hours and possibly 72 since I applied it and it's still sticky to touch. It holds its shape and if you push your finger in it, it will leave a finger print that self heals(goes away after a few seconds)
I'm sure it's water tight, but will get covered in dirt and other crap.
My shop is airconditioned, so the humidity is low(Sika cures from moisture in the air) but I squirted a mist on one seam and it didn't help 24hrs later.
I know if you tool it with alcohol it will never cure. I had used alcohol to clean the sheetmetal, but was very careful to let it dry, and even wiped any potential residue off with a rag. I had put a big gob of the Sika on a spare piece of sheetmetal that wasn't cleaned at all, and that Sika is also sticky like the rest, so I have a hard time believing it is related to my prep.
Anyone ever have this happen? It's going to be a real pita to get off.
Sent from my Passport
