I have a skamper 060s and the roof leaked pretty bad this winter. one of the roof boards was pretty soaked. I pilled down the ceiling liner and could push my finger thru in a few spots. The boards are still adhered to the aluminum roofing in almost all spots but have been saturated in other areas. I think most of their surface area is salvageable. Now here is where I need the advice.
I am going thru a divorce and have no time or utility for an advanced roof removal and repair project. Nor do I have the extra hands to help me facilitate such a big job. What I was thinking about was the following:
1; reseal the roof from the outside to stop all leaks. I believe it is the main center seam that has caused the issue. (i'll use rubber rv paint or something)
2. remove the ceiling liner on the two rear panels that show damage. (the front two boards are perfect)
3. Let it all dry out (super dry)
4. Find the areas with the most damage and cut/scrape a chamfer in those areas approx 1 3/4" wide from one side of the camper to the other to expose the aluminum roof from the inside
5. make my own microlam using 3/4 pine and 1/4" plywood
6. Glue the microlam in the chamfers and support so they adhere well
7. flake off any additional board flakes and then paint with several coats of Kilz to the point where its almost a hard surface
what do you guys think? I figured i could make the microlam with the very slightest outward curve to drive water off the sides as well and take up any droop that has occurred as a result of the leak
