Hey all,
here is our build thread.
http://www.expeditionportal.com/forum/threads/141578-F550-Surf-Camper-Build-Adrift-in-the-Green-Room
We have an articulating wall in our cabover section. It nests in the down position, but goes up to cover the area that would normally be covered by a tent when the top is up.
I have it operating well with a stainless tube and cable system that is embedded in the ceiling. What I'd like is a small winch or reel that allows me to control the position with a handcrank, as in non inclement weather, non buggy campsites, I'd like to be able to lower that wall down and leave the front open.
We are using .125" vectran cable, and the wall only weighs 25lbs (composite), so I need something low profile, lightweight, surface mountable, with a removable handle. Also needs to be reversible and controllable with the handle in both directions, as well as capable of handling small cable diameters. It would also ideally be able to accept cable coming from opposite directions, one wrapped over, one wrapped under, but I could bypass this need with a pully to reverse direction if needed. Also only needs about 10" of travel. Most things Ive found are far too heavy duty and big. Trailer winches look right, but again, smallest is about 2000 lbs capacity. I need maybe 100lb capacity.
Been looking at things like these, but nothing really has fit the bill yet.
Thoughts on product category to hone in on?
