Airmapper
Inactive Member
I spent my first few nights in the Smittybilt RTT, no major complaints on the tent itself, all went well and I set up and packed up 2 days in a row.
The annex on the other hand....:ugh:
I didn't need it but I went through the process of setting it up as if I was going to use everything. The annex design is just stupid. It will work, but it's a nuisance.
On further research, mine is not designed like these photos floating around:
The way mine attaches, the ladder must be inside the annex. Then door to the annex then covers the ladder.
To access the ladder, the door and screen must be rolled up and fastened. This means if the RTT is in use, your annex is wide open, where bugs and rain can blow in.
But there is a secondary issue, to get in the annex, you have to squeeze around the ladder. I had it all set up, then needed to get my bedding out of the truck on that side. It has an access door on the vehicle side, no biggie, but once I had an armful of stuff leaving the annex to get around the ladder was a clumsy task.
This could all have been solved if the annex attached inside the ladder, hanging straight down, with no access door there, maybe a screen window like on the sides. Put the access doors on the sides and one to the vehicle side. That way it wouldn't block the ladder or your access to the room.
If someone sees how I did it wrong and that leads to the issues, please let me know. However it pretty much only goes on one way, I can't see where I goofed. I thought maybe it was inside out later, but even if it was I don't see it changing anything functionally.
My recommendation, do not get this design annex if you can avoid it, or beware it's out there.
So is mine some old revision design?
