NMC_EXP
Recently bought an FJ60 with 2F engine outfitted for the trail by a previous owner.
As received it has the Safari Snorkel intake ductwork installed on the pillar and through the right fender. Also installed (but not hooked up to the carb) is a 3FE bottom filter housing with Aussie lid (got an Aussie carb plenum and flex hose in a box with the deal).
As it stands now, the unmodified factory air cleaner is still in use. The 2F engine has not been desmogged.
Based on threads at IH8MUD, the previous owner wanted to keep the vehicle smog legal. He got this far before selling the 60 to buy an 80.
Twenty years ago I would have bought a non US carb and distributor and completely desmogged this thing ASAP.
Objectives:
1. As things stand now, I do not want to desmog the engine.
2. I will not intentionally cross water more than bumper deep.
3. Probable second battery installation at some point.
Options:
1. Remove the snorkel and 3FE/Aussie filter housing. Patch the holes in the fender and pillar. Run with the stock filter housing.
2. Leave the snorkel intake installed, and remove the 3FE/Aussie filter housing. Run with the stock filter housing. In other words, a fake snorkel.
3. Modify the 3FE/Aussie filter housing to accept the 2F smog plumbing.
4. Modify a 2F filter housing by: (a) relocating the intake "horn" to the right side to mate up with the snorkel supply line, and (b) relocate air cleaner smog plumbing hook ups. Would lose the hot air intake.
Where I'm at:
1. I tend to believe running a snorkel with precleaner will extend filter life in dusty conditions, and the stream I thought was bumper deep may not be. That being said, I'm still not dead set on having a snorkel.
2. The 3FE filter housing takes up a lot of space behind the battery. Is that a place to install an auxillary battery ?
3. Moving the factory air horn to the right side would free up space to left of the radiator for an auxillary battery (this would require eliminating or relocating the radiator overflow tank - the dominos fall).
I'm leaning towards running it with the snorkel and modified 2F filter housing with smog. Anyone have any experience with this as in is it practical and effective?
Sorry about the length of this - trying to anticipate questions.
Regards
Jim
Objectives:
Options:
Where I'm at:
Regards
Jim
