RK...I suppose the 4" kit is available right away too. Now that I have the rear bracket sorted...adding material to the Add-a-Lift-Traction Bar is easy for any desired rear lift height...2.5+
The front is a 2" subframe/body spacer...all additional lift must come from adjusting the torsion bar preload....up to 2" from stock...3" if using aftermarket 'keys' and imposing absolute havoc on your steering components.
I'll be having steel risers welded in on my second van to give a 5" 'body lift'...but this is very custom, not sellable, and I expect that most will have a very hard time finding a shop that would even do it if they couldn't confidently do it themselves.
So a 5" BL and a middle ground 1" torsion bar tweak...6" lift in the works for my '96:drool:
The 2.5" in my '97 is now complete and ready to roll. Reproduction in progress:chef:
