bikerjosh
“The great snorkel debate”
I’m sure this has been brought up before, but is there a consensus on when you should have your snorkel facing forward versus backward? I’ve heard that you should run it facing to the back if snowing but in the rain forward: I don’t understand why but there you have it. It would seem if traveling in a group off road in a dusty/sandy environment you should face it to the rear to avoid clogging up your filter prematurely. Does facing it forward give you a better flow of air into the engine like a ram intake? Does facing it backward, make the engine work harder getting air in?
Ok thanks, I think that is about it.
Josh
Josh
