Need For Speed
Supporting Sponsor
SNUGPAK BACKPACKS-
Snugpak Crossover
The Crossover™ by Snugpak® is another sought after and requested product. The Crossover™ is a great single shoulder strap day pack for anyone. With its single shoulder strap criss crossing over the owners chest it makes it easy to put on and take off as well as very comfortable. Also there is a small section of MOLLE webbing on the waist strap where someone could place and use a pouch for a cell phone, flashlight, knife etc. Also there is webbing on the shoulder strap as well where a phone or portable radio could be attached and also a hydration drinking tube could be routed and secured for easy access. The Crossover™ also has a hidden compartment that can be accessed from two different zippered openings. The concealed compartment has one panel completely covered in Velcro® to attach various pouches like maybe for a handgun, knife, mace, money, passport, etc.
Available Colors: Olive, Black or Coyote Tan
Snugpak Sleeka Force 35
The Sleeka Force 35™ has a central compartment of 2135 Cu. In. / 35 litres which makes a great little daypack and gives more than enough space for your daily essentials. The two toggled side compartments are great for storing those things you need readily accessible. It also has contoured and heavily padded shoulder straps faced with textured high wicking fabrics ensure comfort even under the heaviest loads. There is a zipper compartment on the top and bottom. The top zippered compartment is a great place to store those essentials that need to be easily accessed. The bottom compartment also houses a roll away waterproof cover.
Snugpak Xocet 35
The Xocet 35® by Snugpak® has received rave reviews. The Xocet 35® has a lot of great features that many will like and appreciate. There is a roomy main compartment for your gear with a Hydration system sleeve and an outlet port through the top to run the drinking tube. Also the main compartment has an organization system to help store and arrange various items. There is also a zippered storage pocket for those items you want to keep secure and accessible. There is also a front storage pocket to conveniently put items that are needed at a moments notice. Also both sides have a mesh pocket with bungee cord tensioning for items such as water bottles and clothing. Lastly the Xocet 35® has 5 rows of MOLLE webbing on the pack to allow the user to add MOLLE compatible system pouches they might need such as utility, accessory, ammo, radio, etc.
Snugpak Endurance 40
The Endurance 40™ by Snugpak® is based off its popular Stamina 40™ rucksack platform and design. The main, and noticable difference, is a MOLLE webbing on the front and both sides. The Endurance 40™ still has a Hydration Sleeve as well as a routing port for the drinking tube and the storage pocket on the lid. It also has contoured and heavily padded chest straps faced with textured high wicking fabrics. The top lid zippered compartment is a great place to store those essentials that need to be easily accessed. The bottom compartment also houses a roll away rain cover. The Endurance 40™ is a great pack for those who have always liked the Stamina 40™ and Rocket Pak™ but always wanted the availabilty to attach additional pockets for various things.
Available Colors: Olive or Coyote Tan
Snugpak Stamina 40
The Stamina 40™ is a streamlined, multi-purpose, single chamber 2440 Cu. In. / 40 litre backpack. The superb back panel system consists of a heavily padded air permeable system for comfort and outstanding back protection. It also has contoured and heavily padded chest straps faced with textured high wicking fabrics. There is a zipper compartment on the top and bottom. The top zippered compartment is a great place to store those essentials that need to be easily accessed. The bottom compartment also houses a roll away waterproof cover. The Stamina is a great in-between backpack for those that cant make up their mind up on either the Sleeka Force 35 or the Rocket Pak.
Snugpak Rocket Pak
The Rocket Pak™ has a very spacious and versatile 2440 Cu. In. / 40 Liters main compartment. It contains an aluminum removable stay. Removable Stays can be removed and then bent to fit your back. It also has in internal pocket/sleeve for a hydration system. Also another unique and versatile feature of the Rocket Pak™ is it’s two removable side pockets (915 Cu. In / 15 Liters each) are compatible and attach to the Snugpak® Yoke System. When the side pockets are attached to the Snugpak® Yoke System can be made giving the user a 1830 Cu. In. / 30 Liter daypack. The Rocket Pak’s back panel system is a heavily padded air permeable system for comfort and outstanding back protection. It also has contoured and heavily padded shoulder straps faced with textured high wicking fabrics. There is a zipper compartment on the top and bottom. The top zippered compartment is a great place to store those essentials that need to be easily accessed. The bottom compartment also houses a roll away rain cover.
Snugpak Kit Monster 65 Liter OR 120L
The Kit Monster is now available in a 65 Liter version as well as the tried and trued 120 Liter version. Some refer to the Kit Monster as a carryall. It has a variety of handles and loops which allow the bag to be carried as a hold all, it can be worn on the back as a rucksack when you use the shoulder straps, or just a simple duffle type style gear bag. One unique feature of the Kit Monster that sets it apart from standard duffle type style bags is it is equipped with compression straps that allow the excess volume to be reduced, which in turns reduces the bulk of the bag. The Kit Monster also has grab handles on each end. This is great for those extremely heavy loads when you need a buddy to help you lift it into the helo or onto the boat. Also the grab handles on each end can also be used in conjunction with a carabiner to secure the Kit Monster to prevent it form moving around. A couple of other features are the heavy duty base and chunky zipper.
Snugpak Roller Subdivide
The Roller Subdivide by Snugpak® is our most versatile carry all yet. With two main compartments both with purpose. The bottom main compartment has securing straps to cinch items down to keep from moving as well as zippered pockets on the underside of the upper main compartment. Then the upper main compartment has a C shaped zipper to allow larger items to be loaded into it. On the side with the retractable handle is a nice organization comportment that is great for holding and sorting items like pens, cell phones, chargers, passports and other essential items you need quick access to. Then we have added cinch straps on all four sides to allow it to be compressed when not full, or to reduce the bulk if filled with items that can be compressed. The Roller Subdivide is a great rolling bag for just about anyone and any situation.
Dimensions: 29.5” L x 16”H x 14”W
Volume: 90 Liter - 6608 Cubic Inches
Weight: 113 oz / 3.2kg
Multimat Airlite Inflatable Mat
The Airlite Mat is a manual inflation mat not self-inflating like most of the other mats Multimat is known for. The Airlite mat has two inflation valves on one end to aid in quick inflation and deflation. Packs down to almost nothing and weighs virtually nothing at just under a pound.
Multimat Trekker Mat
Temperature Rating: 14°F to 112°F (-10°C to 45°C)
The Trekker Mat by MultiMat is quickly becoming the choice of many Military personnel. The Unique design and color combination sets the Trekker apart from the competition and the choice of Military Professionals. Self-Inflating Mats not only provide a little extra comfort sleeping on top of rocks and other hard surfaces but also help to add a barrier between you and the cold ground beneath.
Snugpak Crossover
Snugpak Xocet 35
Snugpak Stamina 40
Snugpak Rocket Pak
