Please email me at the CL ad below:
https://inlandempire.craigslist.org/cto/d/1998-toyota-tacoma-5spd-with/6759395010.html
Reason for sale: moved onto a new rig
Clean title
203k miles
3.4l v6
No locker
Manual windows
LineX bedliner
Tundra brake caliper upgrade to assist with extra weight in rear
new OME (Old Man Emu) front/rear suspension with air lift rear bags
new 16" BFG K02 miles <1500 miles
Motor runs strong and has been taken on multiple road trips to AZ, UT, NV, Northern CA and back without any hiccups
Cold AC
Truck is due for timing belt/waterpump preventative maintenance.
Camper details:
Four Wheel Camper Ranger II
unk year
no leaks in roof
refrigerator propane line has cracked-used as an ice box
working sink w/ manual hand pump or electric pump
10gal fresh water tank
2 burner stove
dual 6V golf cart batteries
CTEK D250S battery recharging system-charges camper batteries while driving. System is solar ready and CTEK has a built in MPPT controller
heater works-although it is loud may need some lubricant or minor servicing
bench seating that turns into bed
memory foam mattress on cabover section
Front panel has been missing for some time. Wooden blocks used to prop the top up, rear panel is still there and works however it may be on its way out. Was always still able to use the camper without any issue.
No tears in fabric
2 air vents on top
rear exterior on right side cosmetically damaged/dented in by previous owner
Clean title
203k miles
3.4l v6
No locker
Manual windows
LineX bedliner
Cold AC
Camper details:
unk year
no leaks in roof
2 burner stove
No tears in fabric
2 air vents on top
