SoCal Garage Sale
SoCal_80
Need to thin the kit out a bit....So throwing a few items up for sale. I am located in Long Beach for local pick up. Items are accurately described below. :costumed-smiley-007
- Snow Peak Iron Grill Table Frame 830 Set (CK-147). This is the 3 space table which will allow up to 3 items such as a Baja Burner, single BBQ box and a spacer/cutting board or a double bbq box,etc,etc. The table is in great/darn near new condition and only used on a few trips. New is $210 + tax. $170 local pick up
(Stock photo)
- IGT (Iron Grill Table) Long Storage Case CK-110BR. A sturdy canvas case designed to carry your four unit Iron Grill Table Set along with your favorite inserts. (I used it for the 3 unit and it works great).Case is in great condition with perhaps a few areas with some dirt on it from normal backcountry use. $80 new, $50 local pickup.
(Stock Photo)
- Snow Peak IGT Stainless Tray Two-Piece Set (CK-120). Stainless Tray Two-Piece Set fills voids in unused areas of the Iron Grill Table Frame with heat-resistant stainless steel. The two stainless trays displace one IGT unit and maximize tabletop space for cooking gear, cutting board and ingredients. Near new condition. New $30 + tax. $20 local pick up. http://www.snowpeak.com/grills/iron-...et-ck-120.html
- (2) Snow Peak IGT Slide Top Half Bamboo (CK-153T). The IGT Slide Top Half Bamboo slides into the side of the Iron Grill Table Frame and provides additional work or eating space. Up to four IGT Slide Top Half Bamboos may be fitted to a single three-unit Iron Grill Table Frame, two on each side. I have two in great condition and include the protective zipper cases for each. New for both $100 + tax. $70 local pickup.
- PIAA 525 – “H4 twin light system to give your vehicle a clear high beam and plasma ion low beam with blue reflector”. Very cool dual beam lights..Yellow low/fog beam and white high beam. Also has led bulb to connect to parking lights if you wish. Everything is included and they look and worked as they should when removed with very low use. (2) wires were cut to facilitate passing through the fire wall which then can be butt-spliced back after your install. Really nice lights I just changed things out to a led bar and TJM 220’s up front. $333 from Amazon (http://www.amazon.com/PIAA-5250-Seri.../dp/B00067BUGK ), $200 local pick up.
- Hodgeman Wadelite Breathable waders. New in box. $50 on eBay. $25 local pick up
- Hodgeman "Classic" wading shoes. New in Box. Size 9. $50ish on eBay. $25 local pick up
FiscAnd
