I guess you would be correct and the little bit of info I can find about the controller says lead acid battery and does not have the switching capability like a morningstar.Flooded" vs. AGM.
yes very fast, charge at higher voltage than the Agm can take . agm needs a lower charging voltage in order not to overheat.Can a solar charge controller made for lead acid battery ruin a Agm battery?
