Solar Dual Battery
Luke
I've been reading all the past threads on solar and dual batteries and I am looking for some opinions. I don't run very many electronics in my truck so I'm not looking to power a fridge or anything. Pretty much the only thing I'm running is a Yaesu 7800. That being said I don't really need a heavy-duty deep cycle battery and just want something for back up. So I'm considering buying a regular sized battery and mounting it in the open area near the front passenger wheel well in the 2000 Tacoma, and keeping it charged buy mounting a flexible solar panel to the top of my topper on the bed. I could then connect the second battery to the main battery with a simple on/off switch to keep them seperated until the need comes for jumping my primary battery (worst case scenario). One problem I can forsee is getting the panel mounted in a way that doesn't allow water and dirt to gather under it and ruin the paint on the topper. Overall I don't think this would end up being very expensive and pretty comparable cost to a conventional dual battery system with isolators and switches.
Any thoughts?
I'm pretty sure you will need a voltage regulator as well. Check with the people at RV Solar Electric and they can set you up inexpensively, that's where my system came from, and they have many sizes.
Bobbyjr
