SOLD—new Superwinch 1695201 Talon 9.5SR - $800
elvi679
SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD - SOLD -
New Still in banded crate - Superwinch 1695201 Talon 9.5SR, 12 VDC winch, 9,500 lb/4,309 kg Capacity
This is the industry's best truly sealed vehicle recovery winch assembly. All seals on the entire winch meet the IP67 standard, from the outermost end of the high performance motor and groundbreaking solenoid to the 2-stage planetary and 2-stage spur gearbox.
The sealed 5.2 HP motor delivers a quick but safe 62 FPM line speed at a low 75 amp draw. Heat sink-styled motor cap maintains low temperatures under the heaviest loads.
The solenoid will keep out water, mud, snow, and dust and has a patented venting feature that allows the contacts to resist water and release contact damaging internal condensation. The VS4 Solenoid (Vented, Submersible, and Stabilized with Sealed Socket) is simply the best winch solenoid in the world, and it's located inside this modern-styled rugged enclosure.
Covered by a Limited Lifetime Warranty, which includes an industry-first 3-year warranty on all electrical components, the absolute BEST in the INDUSTRY!
Superwinch synthetic ropes are genuine AmSteel-Blue™ with Samthane™, a special coating to help resist abrasion. The raw material in AmSteel-Blue™ is made from genuine Dyneema® SK-75 HMPE fiber, "which is the worlds strongest fiber™" made by Samson Rope Technologies.
AmSteel®-Blue is a torque-free 12-strand single braid that yields the maximum in strength-to-weight ratio and, size for size, is the same strength as steel--yet it floats. AmSteel®-Blue outlasts wire 3:1, making it an excellent wire rope replacement. It has extremely low stretch and superior flex fatigue and wear resistance. Average strength is 19,600 lbs. and minimum strength is 17,600 lbs. Elastic elongation is only 0.96% at 30% of the break strength.
I purchased this and have decided not to install on my vehicle - my loss is your gain.
WILL SHIP and will only charge you the true costs - but keep in mind that DUE TO WEIGHT this could get pricy...... LOCATED IN COLUMBUS, OHIO
Alexk
