**SOLD** 1994 Stewart & Stevenson LMTV w/ Fully Converted Habitat
Sclipary3
Fully converted with all the components for off-grid travel, this go-anywhere rig is incredibly fun for adventure & exploration! The truck is a 2.5 ton 1994 LMTV M1078, manufactured by Stewart and Stevenson for the United States Military. This truck has 4WD and approximately 20,000 miles. This truck is well-maintained and thoroughly checked before, during, and after every trip. All maintenance is logged/noted. Here are the details…(video walkthrough link also below)
Truck: Cat 3116 6.6 liter diesel engine Automatic W-tec II Alison transmission Full time 4WD, 30/70 with 50/50 mode Dana differential locker in rear Arduino CTIS (Central Tire Inflation System), which means you can inflate and deflate the tires from the dash Pacbrake exhaust brake Upgraded 210 amp alternator 310 horsepower tune AC in cab Zero torsion subframe Sound deadening and insulation Stereo with Apple carplay Custom roof rack with storage boxes Upgraded 3.07 highway gears (gives a max speed of 74mph) Webasto hydronic engine heater 1500 watt block heater New pinion seals in front and rear Rebuilt and serviced all 4 CTIS seals in hubs New U joints Custom exhaust system Custom air intake 25,000 lumens in off road lights GMRS/VHF and CB radios Full siren and PA system Custom train horn 4 point camera system with DVR Custom aircraft joystick with camera controls and to control engine braking Exterior storage boxes Sherpa 25000 lbs winches, front one needs to be rebuilt 2.5 inch receiver hitch in front and rear Custom crane on roof rack to lift heavier items Custom storage rack in cab to hold Pelican cases 200 AH battery in cab (seperate from starting and house batteries) to power lights and cab accessories Cab is wired for solar 1000W inverter in cab Two external 15 lb propane tank storage Custom brush guard for solar panels and vents Hydraulic system is fully functioning Raptor liner paint job
Camper: Fully built out for extended offgrid travel Welded aluminium interior frame Heavily insulated camper shell 100 gallon freshwater storage Chinese diesel heater 3 burner propane stove with oven 700 watts of solar with 60 amp controller (Victron) 600 AH battery bank (Renogy) 3000 watt pure sine inverter/charger (Renogy) 2 Dometic fantastic fans Simarine tank, power, and temperature monitoring system Isotherm 200 liter fridge and freezer Composting toilet with 5 gallon yellow tank 5.5 GPM water pump with XL accumulator tank 0.5 micron water filtration system Indoor and outdoor shower 4000 watt gas generator Furrion tankless on demand hot water heater ArcticTern windows and bear proof door Dinette that seats 4 Ample storage Smart TV on swivel Double bed Tank and pipe heating Weboost cell phone signal booster Smart mini router Large storage for multiple bikes and gear inside of camper Crane and side door to lift bikes and heavy items into a camper Newly installed retractable awning to extend the living space even on rainy days.
Video walkthrough and interview with previous owners featured at 2021 Overland Expo:
Vehicle being sold AS IS. We’ve begun work to upgrade a few things but find ourselves unable to continue due to job changes & a move. The majority of the truck is unchanged from what you see in the video & photos. Our loss is your gain because we need to move this fast - come see it today. Asking $84,500 and open to offers. Serious inquiries only - call or text Jonathan @585-698-8981
464462493_1075580030840245_834452835255304693_n.jpg464191817_1053892042893114_4640330975464734002_n.jpg464395486_1244987779981414_1225514287972070365_n.jpg464504077_519107837710960_2998254376226884815_n.jpg464532783_1091257235905087_970064253017743454_n.jpg464516886_1604932013740327_6140912747049213775_n.jpg464437526_1019515799976741_854436643416969449_n.jpg464404356_7996002137166948_4069527908783483095_n.jpg464362350_954601953368605_2445482085940222811_n.jpg464191817_1758458661562504_250358172839888885_n.jpg
Sclipary3
Vehicle being sold AS IS. We’ve begun work to upgrade a few things but find ourselves unable to continue due to job changes & a move. Many have asked what are the top things that require attention, so posting those here:
1. Replace water heater - there's a leak somewhere in the hot water heater (we think from past improper winterization). The cold water runs without issue so tank & plumbing are all in good shape, but we were planning to replace the hot water heater.
2. Electrical gremlins - there are (what we believe to be) 2 separate gremlins in the electrical system we haven't yet tracked down. First is that the habitat battery bank isn't properly charging from shore power. It charges (and generally remains adequately charged) from the solar panel system, but on the occasion we've plugged it into shore power, something isn't quite right. (It's also worth noting that all of the habitat batteries were replaced 2 months ago). Second, the starting battery (which is on a separate circuit from the habitat) has a slow drain from an undetermined source and we've kept it plugged into shore power when not in use to avoid killing the battery all together.
3. Cosmetic - We started to "remodel" the galley and pulled the fake sticky tile off the walls with plans to replace it with something nicer, but have not yet done so. I'm sure any new owner will also have their preferences for additional decor upgrades.
PLEASE NOTE WE ARE HIGHLY NEGOTIABLE! THIS AMAZING TRUCK NEEDS A NEW HOME AND ALL REASONABLE OFFERS WILL BE STRONGLY CONSIDERED!!!!!!!!!!!!!!!
Sclipary3
Additional & Updated Photos:
