*SOLD* 2001 Roadtrek 190 Popular
magnells
Very Good Condition
Massachusetts
$22,500
Our 2001 Dodge Roadtrek 190 Popular is for sale. It has 156,7XX miles on it and has been well cared for.
It is a 2001 Dodge 3500 Ram Van, the 19' one-ton van with a 5.2L V8 and automatic transmission. It has a Fiamma awning and Continental tire kit.
In the last two years the following vehicle components have been replaced or added:
Updated steering with new Tie Rods, Idler Arms, Drag Link and Lower Ball Joints
Timbren Suspension Enhancement System on Front and Rear
New Front Brake Pads
Rebuilt Transmission
New Steering Box
New Engine Battery
New Tires
New Front and Rear Bilstein Shocks
New Brake Lines and Rear Brake Cylinders
New Front Wheel bearings
The standard kitchen, with two-burner propane stove, microwave oven, three-way 3.0 cubic foot refrigerator and stainless steel sink, has been updated with a single control faucet and a separate 3M filtered water dispenser. In addition to the six gallon hot water heater and propane furnace, a new AC-powered air conditioner was installed in 2015. It has a marine flush toilet and inside and outside hot showers.
Tankage is: 26 gal. fresh water, 20 gal. gray water, 10 gal. black water, 8 gal. (35 lb.) propane, 35 gal. fuel.
For entertainment, there is a 13" flat screen TV with a separate DVD player. In addition to the standard interior lighting, five flexible stalk reading lamps have been added, one at each seat and two over the beds. There are also five automotive 12-volt power ports and five USB charging ports installed.
For power, there are two brand-new AGM deep-cycle batteries with 150 Amp/hr capacity. These are kept charged by either the engine alternator, the 30 Amp shore power connection, the 2.8 KW Onan generator or the added 215 Watt solar panel. The solar power addition includes the 215 watt Kyocera panel, a Blue Sky Solar Boost 25 MPPT charge controller and a Tri-Metric TM-2025 battery monitor.
It also has a Class III receiver. We've used it to tow a 10' cargo trailer with two GS's out west a couple of times with no problems (even over passes in Colorado).
Many more photos are available at https://slate.adobe.com/cp/SSFt8/
But here are a few to start:
Happykamper
Wonder how much it would cost to add something like a quiggley under this . If doable and not ridiculous I would be interested.
iStan814
