SOLD SOLD SOLD SOLD SOLD SOLD
2005 Jeep Liberty Sport CRD
128,xxx miles
Runs great, good gas mileage, turbo diesel, 4wd, cruise control, hitch. Great for road trips. Always used synthetic Rotella oil. Wired 120V outlet for charging phones, etc. Rear cargo area carpet was replaced with rubber for easy clean up. Rubber floor mats in front and rear seats. Hard wired MV-50 air compressor as well.
The MAF sensor is unplugged to deactivate the EGR valve and prevent the intercooler/intake being clogged. The check engine light is on because of this. Will go out when the sensor is plugged in. Also have a kit to eliminate check engine light, just never got around to installing it. The crankcase vent also dumps below the engine rather than back into the intake.
The one negative is the transmission shifts poorly from 2nd to 3rd. The computer has a bad value stored for the clutch fill volume so it shifts hard. It's done this off and on since I've had it. Reflashing the transmission computer and doing a self-learn will fix it for awhile and then it comes back. Replacing the TCM will fix it permanently, but it's never bothered me enough to fix.
I do have a dog so it's not immaculate inside. I drive with the rear seats folded nearly 100% of the time and the rubber mat in the back does a good job keeping it clean though.
Extras: custom welded 2 bike rack, roof rack cross bars, thermostat, serpentine belt, fuel filter, headlight bulb, CAT fuel filter adapter, 1.25" spidertrax wheel spacers, Fumoto engine oil drain valve.
Maintenance History:
24000 Bought
28920 Firestone Destination A/T tires 245/70/R16
60476 ARB OME shocks and springs installed
68114 New pads/rotors
102343 Firestone Destination A/T tires 245/70R16, inner & outer tie rod ends, added spacers to front struts to increase lift
121116 Timing belt, water pump, timing tensioners, front hubs/wheel bearings, rear driver's side brake caliper, rear rotors & pads
123107 New alternator
Pricing based on all Liberty CRD's for sale within 200 miles of Milwaukee, WI on autotrader.com and adjusted for mileage. I did a quick regression analysis and based on that the price should be $10k. This seems high based on the condition so price is $8,000. I am open to fly and drives and will drive it to you (ANYWHERE in the country, with deposit, if you cover my return flight). Will trade for a truck (plus cash on my end).
128,xxx miles
24000 Bought
