SOLD: 2006 Tundra Double Cab 4x4 Limited - San Diego
tplane2
Good afternoon ExPo. I'm putting my Tundra up for sale due to a move to Japan. Available September 6th. Located in North Park, San Diego.
2006 Black Double Cab Limited 4x4 with 4.7 V8 and 227k Miles. Asking $10,500
Just smogged last month and registration is current until FEB 2021.
Clean California Title in hand. Clean Carfax.
The truck has lived its entire life in San Diego so no frame/rust issues. I'm the second owner. The first owner owned until 210k before I purchased it from him about 2 years ago. It was serviced religiously (see below) by the PO through Toyota of El Cajon. I took over and maintained with all OEM parts since purchase. I have a two inch stack of Toyota Dealer receipts that will go with the truck.
The truck has been extremely well maintained with many of the major expenses taken care of. The drivetrain is near perfect in this truck. Everything works.
The paint itself is in really good shape for the age. No fading or peeling clear coat, but the exterior does have some dents, dings and scratches, especially the tailgate and the rear bumper. The passenger side front door have a larger horizontal scratch. Please see the pictures.
The interior is in good shape for the year and mileage. The driver's seat does have some light wear on the side bolster and in the center seams. The steering wheel has some wear at the top. The passenger side footwell carpet has just a small amount of wear that is visible. The original floor mats are actually in great shape.
The only aftermarket items are: Skid Row skid plates that I just installed. Front skid and front differential skid. Those and Bilstein 5100 shocks.
225,000: OEM Front Lower Ball joints. Oil ChangeTRD Wheels. 285/75/16 BFG KO2 Tires. Approximately 60-70% Tread.
220,000 Replaced blown factory JBL speakers with JBL aftermarket speakers.
215,000 Replaced Serpentine Belt + TPMS Sensors. (Later disabled the system)
213,000: Replaced tailgate handle
212,000 Bilstein 5100 shocks. Currently set at the lowest "1st" notch. No rubbing.
210,000 Oil Change Toyota of El Cajon
206,000 Oil Change Toyota of El Cajon
200,000 Oil change Toyota of El Cajon
198,000 Prop Shaft and Battery Replacement: Toyota of El Cajon $2100
194,000 Oil Change and Air Filter: Toyota of El Cajon
190,000 Oil Change and, tire rotation, re-torque prop shaft: Toyota of El Cajon
184,000 Oil change, Headlight restore and headlight bulbs, rotate tires, inspect ball joints, inspect steering, lube prop shaft.
183,000 Replace Front CV axles and Toyota of El Cajon: $1877
180, 000: Oil change.
175,000: Timing belt change, throttle body cleaning: $787
170,000: Oil Change
165,000: Driver’s side Door handle replaced. Oil Change
159,000: Oil change
155,000: Replaced serpentine belt and tensioner, oil change
154,000: Full Brake job and taillight bulb replacement
150,000: Oil Change
147,000 Oil change and 145k mile service. Headlight restoration
139,000: Transmission drain and fill, brake fluid flushed, fuel injectors cleaned
135,000: Oil change and checkup
130,000: Oil change
120,000: FULL 120K Insepction, replaced spark plugs. Replaced spark plugs and gaskets, Left and right CV boots
115, 000: oil change and service
109,000: Oil change, recharged A/C
104,000: Replaced Waterpump (warranty), brake pads, battery
99,822: Replaced Rack and Pinion, Power Steering Pump etc $1482
94,000: Replaced Driver’s Side exhaust manifold. $835
90,117: Timing belt and Water Pump Replacement, full 90k service $1284
85,000: Oil Change
79,000: Oil Change and brake flush
75,000: Full 75k service and oil change
70,000: Oil change
66,000: Oil Change
61,000: Rear differential drained and filled. Oil change, brake pads and rotors
54,000: Brake fluid and fog light change
49,000 Oil Change
45,000 Oil Change
42,700 Oil Change
39,800 Oil Change
34,000: Oil Change Tires
Mainly oil changes before this time
Athansinis
Wish this was closer. I'd love to upgrade from my T100, but it's too far for me under current circumstances.
GLWS.
YaRiteZ71
