Sold - 2007 Ford F-550 4x4 Camper - 6 speed - New Camper Build $35k
Bigbird43
2007 Ford F550 4x4 Overland Build
Priced to sell! $45,000
The time has come to sell my converted F-550 camper! I bought the truck in April 2021 and have converted over the last ~2 years. Disclaimer: I'm not a professional but I did A TON of research and I am a mechanical engineer with multiple completed car projects so I'm not a newb either. No reason for selling, the purpose was the build for me, not in a hurry to sell.
2007 F550 4x4 Single Cab
• Manual Transmission 6 speed
• 4x4 with front locking hubs
• Truck/Body: 93xxx Miles
• Engine: 6.0 Powerstroke
o Full rebuild @89k miles. Rebuilt by a shop in Boise ID + additional bulletproofing done here in California (receipts available)
o ARP Head Studs, stage 1 cam, bulletproof egr cooler, oem oil cooler
• 4.88 gears (I've keep it under 2100rpm which is about 60mph)
High Idle Option switch
Tires have 80+% tread
• All Exterior Flood Lights work
• 24’ long 10’ tall
Current Registration/insured in California as Truck with Permanent Camper (No smog and cheap insurance)
Carplay Double Din with backup camera
Back Box
Interior height in center is 69"
Internal Width 85”
Internal Length 135”
Electrical
o 3x100Ah LiFePO4 Batteries (SOK)
o 2x330W Solar Panels (Panasonic SC330)
o Victron SmartSolar 100/50 MPPT Charge Controller
o Victron 30A Orion DC-DC Charger
o Victron Lynx Distributer
o Victron BMV-712 Battery Monitor
o 2000W Inverter/Charger - Pure Sine Wave (Progressive Dynamics PD1620A)
o Marine Wire used throughout
o 4x 12v Outlets (2x bed, 1x kitchen, 1x front of galley)
o 3x 120v GFCI Outlets (1x Kitchen, 1x bench, and 1x rear slide out)
Appliances
o Indel B Truckfridge TF130L 12V Fridge
o 1800W 2 Burner Induction Cooktop
o 8x Dimmable Puck Lights
o 5kW Diesel Heater (Chinese - Vevor)
o Tec Vanlife Sink – faucet folds and comes with cover
o MaxxAir Fan - Manual Lift - 10 Speed + Auto control
Structures
o Marathan Tweed Padded Walls (Same Style as OutsideVan)
Stick on Vinyl backsplash
o Ikea Maximera Cabinet Lowers - all soft close
o Corian Solid Surface Countertop
o Luxury Vinyl Plank Flooring (High Quality – was left over from house - Manila Oak Color)
Water
o 55Gal Fresh Water Tank
7 gal grey water Tank
o Shurflow 12V Water pump with accumulator and household filter
Other/Misc
o Full size foam mattress
o Insulation – Combination of R13 Polyiso Board and Havelock wool
o Lagun Table
History of the truck: It began it's life as a Bureau of Land Management HotShot (fire Transport) truck. It was used by the Ruby Mountain Hotshots in Nevada til about 2015 (from what I can tell). I bought it from auction, and picked it up from Elko, NV not running. The engine was torn down and diagnosed that a roller bearing/lifter failure. Decided to rebuild engine because the block looked good, it is studded, and the injectors tested good. Engine build was completed in Aug 2021 and I drove the truck from Boise, ID to SF Bay Area, CA
More images: https://drive.google.com/drive/folders/10_UJR7bgGKYpynQdnHonuEezhBvLxoIm
Bigbird43
Open to the following trades as well:
1st gen tundra crew cab 4x4
2016+ Colorado crew cab 4x4
Would want cash on your end for both of these
DirtWhiskey
Western Dirt Rat
Rad build. Smoking deal, especially with the bulletproofing. GLWTS! If I was in the market I'd be taking a good hard look. Wide track front axle. Short wheelbase for an F550, probably turns on a dime. Love these crew buggy builds. So much better than ambulance bodies as a starting point. Love the rear departure angle. Would be a great skimobile for somebody.
Bamat
Skimobile is exactly where it’s going!
Hairlesswookiee
