1 Bored Clerk
**TRUCK IS SOLD. CAMPER AND SUBFRAME ARE STILL FOR SALE BUT I WILL START A NEW THREAD FOR THOSE*
I'm selling my 2013 TRD Off Road AC Tacoma with custom camper.
$35,000 $31,000
**I'm willing to sell the camper and subframe (with fenders) separately from the truck. It will bolt directly to any 2nd or 3rd gen (2005-current) long bed (6.5') Tacoma: RC, AC, DCLB. Can be easily bolted to nearly any flat bed truck or trailer - 4 mounting points.$8,000 $6,000
Vancouver WA, USA
More images below
The truck details:
1 Owner - Me!
122,000 miles - approximate as it is my daily driver
I have ALL receipts for service on this truck as well as a ton of receipts and manuals for accessories
Auto transmission
4.56:1 gears - built by ECGS - fluid replaced in both diffs this summer
255/80 R17 Toyo Open Country AT (all 5) - 3 of these have sidewall cuts - They aren't down to the casing of the tire as far as I can tell
Hypertech speedo recalibrator - with USB cord. You just need a PC laptop to program for tire sizes/gear ratios
Road Ready steel wheels powdercoated grey (all 5) - same dimensions as a toyota 4runner spare
All Pro Expo rear springs (+500lb capacity at 3" lift)
Fox 2.0 rear shocks
Rear braided steel brake lines
Bilstein 5100 front shocks
OME 887 springs
OEM Sway bar - not currently installed but comes with truck
Front Brakes - 5th Gen 4Runner front calipers, rotors, and dust shields
OEM E Locker
Inchworm E Locker guard
Exhaust re-route
Relentless skids - full set (front, mid, transfer case - w/flat belly)
Long Range Automotive 34 gallon fuel tank
US Off Road winch mount
Warn M8000s with hawse fairlead - synthetic rope
Factor 55 flatlink
Custom rock sliders - w/storage trays - using 1 Bored Clerk bolt on frame plates
Powertank stainless propane mount
11lb propane tank
Off Grid engineering second battery mount
Odyssey PC1400 battery
Redarc Manager 30 battery monitor system
2 - Aux fuse blocks - one in cab and one in camper
All marine grade wiring, terminals, sheath, heat shrink, breakers
12V plug by drivers knee
Ram ball mount on drivers A pillar
Ram wireless phone charger on A pillar
Redarc Tow Pro elite trailer brake controller
Husky Floor Liners - front and rear - OEM carpeted mats will go with truck
Truck Lite taillights
Custom rear bumper with recovery points, toyota hitch (GX470), Flip up plate for spare tire access, OEM trailer plug, OEM 110v plug, OEM backup camera in custom 3D printed housing
Engel MT35 fridge
Engel transit mount - no straps, easy to remove
Custom fridge mount behind passenger seat - original passenger rear jump seat will go with truck
Manager 30 display mounted above fridge.
Yakima roof rack with basket and custom wood/epoxy max trax mount.
No factory wiring has been tapped, cut or otherwise modified in any way. All accessories and accessory wiring is a completely separate loom.
No modifications to frame or body except one hole to get the wiring to the manager 30. A proper wiring grommet was used to seal that passthrough .
The camper details:
Custom aluminum camper subframe with fenders and mud flaps
Custom fiberglass camper with aluminum storage boxes
L-track on top, drivers side and rear
Custom roof rack and aluminum awning mount
Alu-Cab shadow awning - 270 degree
Step stool to get into camper - can leave in camper or store in rear aluminum storage box
Interior storage - Grey Man Tactical molle panel with bags
Custom shock cord storage
3 Ram ball mounts
4 USB ports - 2 in each mount
Max Air Fan
8" foam mattress
New sheet
Padded front wall for comfort sitting up
Fuse block in storage box for additional electrical needs
Baja Designs light in storage box
OEM Tacoma body mounts used as camper mounts to isolate the camper from vibration and flex - works awesome and can be easily replaced years down the road if necessary.
Camper panels are honeycomb core fiberglass - very light and stiff.
The vehicle is in great shape. The paint does have pinstriping and a few scrapes. The suspension has some squeaks and creaks. I use this truck off-road but I am careful about how I use and maintain it. The interior is excellent and the camper is also excellent. I have a lot of threads on TacomaWorld documenting the build if you're interested.
I built the camper, sliders, bumper and fridge mount. All have been in service for several years without issue.
There has been a ton of heart and soul put into this truck and it has taken me some very cool places. The camper was built specifically to be tough, light and any condition capable and it has been just that. I'm happy to answer any questions. Thanks!
Vancouver WA, USA
More images below
The truck details:
1 Owner - Me!
Auto transmission
Fox 2.0 rear shocks
OME 887 springs
OEM E Locker
Exhaust re-route
Factor 55 flatlink
11lb propane tank
Engel MT35 fridge
The camper details:
3 Ram ball mounts
Max Air Fan
8" foam mattress
New sheet
