SOLD - 2015 Turtleback Expedition Trailer
oc7710
Located in Salt Lake City, Utah
2015 Turtleback Expedition Trailer in Bengal Silver. In great condition! An extremely rugged and easily towable trailer that will take you and your family on all your adventures both on and off road! Has all standard options plus many upgrades. Clear title.
Asking $20,000 OBO
Trailer Details:
  • Fully galvanized 2x3 steel perimeter box frame with bed-liner coating on chassis, wheel steps, and front framing
  • 3500lb UCF Flexride Torsion Beam Axle (no need to go spring route)
  • 10” electrical trailer brakes with 7-way round pin trailer wiring and emergency trailer breakaway system
  • Goodyear MTR 35-12.5-17 mounted on Jeep wrangler wheels
  • 2” hitch receiver mounted on swing out tailgate. Used for hitch mounted bike rack - works great and allows use of trailer while bikes are still on it. Great for family biking adventures!
  • Additional 2” receiver hitch on frame
  • 1” Receiver hitches on all corners for recovery points
  • 45” side box, 25” side box and 2 side compartment doors for main cargo storage area
  • 48x32” nose box – partially lined with foam cushion
  • Cargo compartment with one 12V and two USB outlets, and LED lighting inside
  • Lockable pole storage tube
  • Large roof top mounted cargo storage compartment
  • LED lighting strips on all four sides of the trailer provide ample illumination of basecamp area at night
  • Under carriage green LED perimeter “turtle” lighting for low light when camping
  • 2000lb swing away tongue jack with foot
  • 1500lb dual wheel swing away 2” receiver trailer jack for easy maneuvering of unhitched trailer
  • Max Coupler
Electrical:
  • Newer dual AGM Optima Yellow Top batteries (only used on two road trips)
  • Sunforce 12V 10-amp solar charge controller
  • Powermania Turbo M209E dual 12V battery charger
  • Xantrex ProWatt SW Inverter package includes 2000W Xantrex pure sine wave inverter with two 115V outlets and one USB charge port, 150A breaker, one 12V and two USB ports in cargo compartment, and dual USB and 12V charge ports in galley
Kitchen:
  • Rear swing out galley containing large baltic birch pantry shelf with removable towel rack and paper towel holder
  • Baltic birch slide out kitchen with drawers and adjustable pantry storage
  • Tailgate – includes 18x36 brushed stainless steel fold down table
  • 2 burner propane stove with windscreen
  • 11lb propane tank (main) and accessory 5lb propane tank
  • Stainless steel sink with hot and cold Delta single lever faucet
  • Atwood 6-gallon DSI propane water heater
  • 42-gallon freshwater tank! Food grade BPA-free.
  • 12V on-demand water pump
  • One 12V and dual USB ports for powering/charging your devices
  • Fire extinguisher
Comfort Features:
  • CVT Mount Mckinley roof top tent with dual ladders – sleeps 4-6 comfortably
  • 270-degree Foxwing awning with height adjustable stainless-steel mounts
  • Exterior shower with hot and cold water
Rdlooper
This is Bob, very interested, living in McCall and Boise, ID. We have a Mercedes Sprinter and are looking for a trailer to put the gear in. I do not need the tent. Do you have any pics of the front nose box, and the inside of the two side boxes? Do you know the load capacity of the back swing gate with the 2” hitch. I would like to use our Kurt bike rack and two e-bikes on the back.
iStan814
