SOLD - 2016 Overland Explorer Vehicles TDK Trailer for sale.
HowardH
Trailer for sale: Overland Explorer Vehicles TDK $26,000
This is a trailer I purchased a few months ago. My new Overland Explorer Base Camp is being built and I have always wanted to try one of their trailers. Now my Base Camp is scheduled to be delivered the end of the month. I am ready to pass this trailer on to it's new owner.
While I have not used it as much as I hoped I have used it enough to know that it's a really nice unit, like all Overland products it's exceedingly well designed and built.
Most of the data I simple coped from the original listing that I purchased it from. 2016 Overland Explorer Vehicles TDK Trailer for sale. *SOLD* | Expedition Portal
Geat pics are there as well.
Trailer is well balanced and tows easily.
Trailer has spent most of its life in a garage.
It will last a lifetime.
Here are the specs on the trailer:
Specifications:
Body Dimensions: 130" L x 48" H x 60" W
Overall Dimensions: 178" L x 88.25" W x 75.5" H
Weight: 2145 lbs. (dry)
Tongue Weight: 215 lbs. (10%)
Frame:
CNC Laser Cut Steel Tube Frame
2" Receiver located in the Front and Rear of the Trailer
Max Coupler Multi Axis Receiver (6000lb rating)
1.5" HSS tube keyed into the frame to make up areas in front and behind fenders, topped with aluminum checker plate
(2) Stabilizer Legs located at the rear
Suspension:
Timbren 3500 Independent Axles w/Electric Brakes
35" BF Goodrich KO2 Tires
Body/Cabin:
1.5" Foam Core Hybrid Composite Wall Panel Construction
Aluminum Extrusions - powder coat finish
All bonding using tested adhesives - no mechanical fasteners
No wood products used
Left and Right Side Doors - includes tinted sliding window with screens
Integrated Front Storage Cabinet:
Solid lockable access doors, on left and right side
Vented to the outside
2 Group 31 AGM Batteries
Under trailer rock lights
Interior:
Inside Cabin Dimensions: 57" W x 80" L
(2) Dometic Windows
(2) Aluminum Cabinets with a storage tray between them
Doors on each side with integrated windows
10 speed Maxair Cabin Roof Fan
USB 12V connections
LED Lights
Exterior:
Exterior LED Lights - one on each side above the cabin door
OEV Custom Aluminum Roof Rack - powder coated (adds 6" to overall height w/33" tires) includes (5) spanner bars. This will accommodate any RTT on the market.
Propane Cabinet designed to house 2-10lb Propane Tank, mounted on the rear driver side of the TDK, includes manifold, regulator, associated piping and (2) quick connects for bbq and gas stove. Manufactured with powder coated (white) aluminum, stainless steel hinges and aluminum positive close latch. Comes with 1-10 lb bottle.
1 - 22 gal Certified Potable Water Plastic Tank, Plumbing, 12V Pump and Skid Plate.
Exterior Front Storage Tray (powder coated (black) aluminum with tie down points)
D.O.T Approved Exterior LED Lights along with reverse lights with a 7 pin connector.
Drip edge above the cabin side doors and the rear kitchen door
Checker plate aluminum rock guard on the front nose
Rear Outside Kitchen:
Galley LED lighting
3 Piece Telescopic Slide Out Kitchen Cabinet: 1st drawer has a sink, 2nd drawer has a storage area for a 16" two burner Partner Steel cooktop and the 3rd drawer is a utilty drawer.
Dometic refrigerator
(3) upper powder coated aluminum cabinets with star board polymer doors with cast aluminum positive close latches
Manufacturers Build Thread for these trails:
https://expeditionportal.com/forum/threads/overland-explorer-composite-off-road-trailer.163240/
Things I have added in the time I have had the trailer:
ARB 2500mm Aluminum Touring Awning
ARB Touring Deluxe Awning Room with Floor. This adds more living space to the trailer and gets you away from the bugs.
Aims 2000 Watt 12V Pure Sine Wave Power Inverter (PWRI200012120S)
SuperSonic SC-1312 LED Widescreen HDTV & Monitor 13.3", Built-in DVD Player with HDMI, USB, SD & AC/DC
2 - Renogy Solar Panels 100 Watt
2nd AGM Group 31 Battery
Infinite Offroad LED rock lights. Wireless remote w/bluetooth app control.
Shurflow 181-201 Accumulator Tank. (Dampens water pump vibrations)
Shelf for additional clothes storage under stock cabinets in the sleeping area of the trailer. Made from 8020 Aluminum/Baltic Birch.
Tires were replaced a couple years ago, but are practically brand new still.
Also including the following camping items:
Small blue rollup table (seen in photos below)
Leveling blocks
Extension cord for inverter.
Privacy Shelter for Shower.
greatwhite24
