SOLD 2017 Borderlands Outpost Trailer
j.mathias
PRICE $18,500
2017 Borderlands Outpost Trailer. Has a lot of options, including:
- 30 gallon fresh water tank (pumpsand plumbing for kitchen and shower)
- Hot springs water heater and external shower (can be ran off battery or propane)
- Water filtration unit (carbon and uv filter) to pump external water, such as from a stream, into 30 gallon holding tank
- Solar package with 2 125w panels (one attached, one moveable) 260 amp hour battery and 1500W power inverter
- Shore power hook ups
- Kitchen with sink and 2 burner camp chef stove built in
- 2 20lb propane tanks
- Off road tires and Timbren suspension
- Rhino Rack and Sunseeker Awning
- CVT Mt Denali Pioneer Extended rooftop tent (this is optional, if you don't want the rooftop tent I will knock $1800 of trailer cost). This is a huge rooftop tent and can sleep a family of 4-5.
This has been a great little trailer. I have built a storage platform inside for gear, which allows for a full size mattress on the inside. I also insulated and carpeted most of the interior to make ore comfort able for sleeping.
j.mathias
Inside the trailer where the mattress is, there is a 12v hook up. So if you did not have the mattress inside and used only the rooftop tent, then you could add a 12v cooler like a ARB, Dometic, etc.
I also was playing with the idea of adding a 12v hookup in the front box, because there is enough room there as well. It just needs the power.
Palli
