SOLD 2017 Ford Transit campervan RWD. Lifted, suspension upgrades, and more. 55k miles. $72k obo located near Phoenix, AZ
BrianBee
SOLD!
Hey all,
It's time to sell our campervan home on wheels. Please check out the details below and let me know of any questions. Located in Buckeye, AZ. Price is $72k but offers are considered. We are remodeling a home so also considering trade work for locals
COPIED DESCRIPTION FROM OUR FB LISTING:
For sale is our 2017 Ford Transit home on wheels. It's been great to us and we would love to keep it, however, we just moved to AZ and are working on a home renovation. Registered in AZ, valid until 8/2022
This van would be perfect for the remote worker or full-timer as it has an extremely beefed-up electrical system and all creature comforts! This home on wheels has hot water, spa shower, composting toilet, stovetop, fridge/freezer, and more! Electrical and water components are all marine grade quality and built to last. 300ah of battleborn lithium will power everything you need. We regularly use a 2000W Breville electric oven no problem. 915W of solar means you never ever have to worry about running out of power. Not to mention a 60A B2B charger that tops off the batteries while driving. Massive 36-gallon water capacity. We go 2 weeks between filling up and that's with two people showering and doing dishes. Upgraded suspension from Van Compass!
I can go one forever so just check out below for more specs. There may be some things that I missed as this van is packed! People are charging crazy prices for their campervans. Compare our van components and upgrades with others in the same price range
VEHICLE
• 2017 Ford Transit 2017 RWD
• 55,000 miles
• Highroof 148” wheelbase non-extended
• 3.7L V6 Engine
• 4.10 Gearing
WHEELS AND TIRES
• BF Goodrich K02 tires - 255/70/r16
• Black Rhino Havasu 16” Alloy wheels
SUSPENSION
• Van Compass 2” Lift and suspension upgrade
• Rear sumo springs
• VC/Falcon rear shocks
• VC Blue Springs with Bilstein B6 front struts
• Optional rear shock bracket relocation mounts
EXTERIOR ADDITIONS
• Aluminess front bumper
• Aluminess rear tire carrier with full size spare
• Raptorliner truck bed liner paint job in Dove Grey
LIGHTING
• RIGID Industries SAE/DOT compliant fog lights
• LED headlights
• LED reverse lights
CONNECTIVITY
• WeBoost w/ antenna mounted to 7-24ft telescoping pole
WATER SYSTEM
• 32 gallon freshwater tank
• 4 gallon Bosch electric water heater
• 36 gallons combined water capacity
• 15 gallon undermounted gray water tanks. 15 gallon for shower, 5 gallon for sink
• Shurflo electric water pump with accumulator and prefilter
• Outdoor wash station or summer showers - cold lines only BED
• This setup is unique as it has cutouts to sleep width-wise. Typically only shorter folks can sleep widthwise in a transit or sprinter. I'm 6'1" and I fit no problem, along with my girlfriend
• Bed converts to a dinette that seats 2, this is also the workstation if working remote
SHOWER
• 24”x36” Shower pan
• Nebia nebulizing shower head with wand attachment
• Nature’s Head Composting toilet • Epoxied cedar paneling on top of FRP water-resistant walls
• Maxxfan mini vent fan with led lighting
• Nautilus self-cleaning retractable shower door
SOLAR AND ELECTRIC SYSTEM
• 915W of solar panels
• 3x Battleborn lithium LifeP04 Batteries
• 300Ah Total • Samlex 2000W Pure sine wave inverter
• Sterling 60A B2B charger - charge system while drive/idle
• Dual Victron MPPT solar charge controllers - bluetooth enabled
• Victron BMS - bluetooth enabled
• Highest quality Marine grade electrical components
SECURITY & SAFETY
• Electric deadbolts w/ killswitches for rear and side sliding doors - doors cannot be pried open
• Front locking partition w/ jimmy proof style lock
• Window cages for rear windows, concealed by insulation and wood panelling
• Optional - front dash cam wired to leisure battery - always on
• Smoke detector and CO2 alarms
KITCHEN
• Ruvati 15x20 deep sink, stainless steel
• Moen residential water faucet with hot and cold lines
• Dometic two burner propane stovetop
• 20lb propane tank with propane locker venting outside
• Isotherm Cruise 130L 4.6 cubic feet fridge/freezer MISC
• Bug nets with magnetic clasps for side and rear openings
VENTILATION AND CLIMATE CONTROL
• 3m Thinsulate insulation on walls and roof
• Polyiso rigid foam insulation in partition and floor
• 3x maxxfans. 1 dedicated to shower, 2 for cross ventilation
• 2x cr laurence bunk windows
• Sirroco articulating fan in bed area
THE GOOD
• Low mileage - plenty of life left on this engine
• Quality Marine grade components
• Suspension is 100x better than stock
THE BAD
• Previous owners bumped into a low clearance overhang. It's cosmetic and doesn't bother us, however, it can be covered with a wind fairing/deflector since it's only the very upper section.
• AC evaporator has a very slow leak. Refrigerant lasts us 3-4 months
• I'm not a professional builder. It's not perfect but it has held up wonderfully, especially since we chose quality materials.
• Normal wear and tear
- small dents on the rear door, small holes in the side bug net
VIDEO TOUR:
