This camper sold. If you’d like us to build you something similar, please check out Our website for more information.
Our custom overland camper is for sale. This camper was built out in 2020-21 on a 2018 chassis. It has been a great platform for adventure with our family of six.
A four season camper, it's been used for ski trips in the winter with a Espar diesel/water heater and all water tanks enclosed in the habitat box.
See more on instagram @bunkhouse_overland
Also posted on rvtrader: https://www.rvtrader.com/listing/2018-Ford-F450+Overland+Camper-5027694314
Truck Chassis
2018 Ford F450 6.7L Powerstroke Diesel, 4wd, 95,000 miles
Regular Cab, XL trim level
Aftermarket CarPlay w/ 9" screen
Rear Camera
Pirelli Pista PS22 335/80/R20 40" tires on 20" steel wheels
Fox 2.0 Performance Series IFP shocks
3" DBL Design lift and custom fenders
Helwig Rear Sway Bar
Air Lift 5000 wireless rear airbags
Habitat Box
Construction is aluminum 0.040" sheeting over a powder coated 2” square steel frame.
Roof and floor were built with 3/4" honeycomb fiberglass panels.
Frame is insulated with XPS foam board - 2 ½” between studs and ½” over studs.
Interior walls are constructed with ¼” plywood.
Windows: Arctic Tern double pane acrylic
Door: Arctic Tern Wildlands
Cargo Doors: Arctic Tern
Skylight: Bomar 18.5" marine hatch
Passthrough between cab and habitat box with removable door
Habitat box is secured to truck chassis with a spring mounted frame to reduce chassis twist transfer to the habitat box. Frame is bolted to chassis in rear with 4x springs on each along the length of chassis rails.
Interior dimensions
197" x 90" x 76"H
Cabover:
60" x 90" (74" mattress, 16" cabinet) x 37"H
Bunks:
29" x 87" (72" mattress, 15" cubbie) x 22"H
Shower:
26" x 23.5" x 75"H
Appliances
Isotherm 195 Cruise Marine Stainless Fridge/Freezer
Empava two burner Induction Cooktop
2 TVs - one in bedroom over cab and one in living area
Sonos Move wall mounted
weBoost Drive
Heating/Cooling
Pioneer 9,000 BTU 20 SEER 115V Ductless Mini-Split AC
Espar Airtronic D2 diesel - air heating
Espar Hydronic S3 D5E - water heating
Maxxair Deluxe 7500 fan
2x Caframo Sirocco II 3-Speed Gimball fans
Power System
24v system
1400 watts of solar panels
800 AH of Lithium. 8x100AH Battle Born batteries
Victron 100/50 Smart Solar MPPT controller
Victron 500amp Smart Shunt
Victron Orion Tr Smart Isolated DC/DC Charger
Victron Orion 24/12 DC/DC Converter
Giandel 3000 watt pure sine wave inverter
AIMS Power Smart Charger for 15 amp shore power charging
AC outlet locations: 2x on back of kitchen counter between seats, 2x below bench, 2x in cabover cabinet, 4x in under bench storage/mechanical area
USB charging ports: 4x on wall next to entry door, 2x on back of kitchen counter between seats, 4x under bench storage area, 4x in each bunk, 2x in each cabinet in cabover bed area
Exterior power: 2x charge ports & cigarette lighter outlet in drivers side cargo area
Interior Lighting: overhead led lighting, 2 zones
Exterior Lighting: 2x LED lights on passenger side, 1 light bar on rear top of camper angled down
Water System
90 Gallon Fresh Water
30 Gallon Grey Water
Thetford Porta Potti 565E toilet
Interior shower (hot/cold)
Kitchen Sink (hot/cold)
Hose bib in passenger side cargo door (cold only)
Seating
2 Seats in truck cab
4 Smart Floor sprinter seats mounted to steel camper frame with Grade 8 hardware. Table between seats can be removed and stored while driving.
Sleeping
6" memory foam mattress (short queen) in cabover bedroom over Froli bed system
3" foam mattress with custom covers in each bunk over wood slats
Storage
Living & kitchen cabinets are residential cabinets with laminate coating with added locking latches. Drawers have magnetic latches
Bathroom: custom shelves with netting
Bunks: custom shelves with netting in each bunk
Bedroom (cabover): custom plywood cabinets
Exterior: Driver side: 2x underbody boxes, Passenger side 1x underbody box, Passenger side cargo door with access to underfloor storage
Accessories
ARB twin air compressor
ARB awning with led light
Rear rack made from 15 series aluminum extrusion with 6 bike rack
Bike repair/wash stand - stowable, mounts to passenger side of camper
Snow chains for rear wheels (new, never used)
Dimensions & Weight
Overall Length: 28ft
Height: 12.5 ft
Width: 8.5 ft
Fully Loaded: 16,500 lbs
Price
Asking $99K
Truck Chassis
Rear Camera
Habitat Box
Interior dimensions
197" x 90" x 76"H
Cabover:
Bunks:
Shower:
26" x 23.5" x 75"H
Appliances
weBoost Drive
Heating/Cooling
Power System
24v system
Water System
Seating
Sleeping
Storage
Accessories
Dimensions & Weight
Height: 12.5 ft
Width: 8.5 ft
Price
Asking $99K
