SOLD 2019 Boreas XT, Many Extras, $17,500 , OBO, Kremmling CO
22sumit
Trailer Chassis
• 3”x2”x1/8” CNC cut steel frame - powder coated
• Timbren Axle-less independent suspension - 3500lb HD
• Alignment 5/23 with replacement Bump Stops
• 30” x 9.5” with 4“ lift kit BF Goodrich All Terrain Tires (Ko2)
• 15” steel pro comp wheels - 6x5.5 bolt pattern
• Electric trailer brakes
• Lock and Roll Hitch
• 7 point electrical harness
• LED trailer lights with reverse
• Upgraded Battleborn 100 AH Lithium battery and Victron Charge controller
• Oversized aluminum tongue box
• 20 gallon water tank with skid plate
• Jeep style fenders with matching diamond plate steps
• Rear crank down levelers
• Full sized spare tire
• Rear 2” receiver hitch (325lbs max)
Exterior
• Composite and aluminum cabin – No wood!
• 11lb propane tank with mount Addition 11lb propane tank added
• 100 watt Zamp solar panel with plug to add additional panels
• Instant hot water shower
• Full ARB room enclosure attaches to either awning
• Custom aluminum roof rack with 2 large cross bars (500lb max)
Cabin
• Propex Forced Air Furnace (6500btu)
• Oversized composite cabinetry
• Composite maple wall paneling
• Fully Insulated walls, roof, and floor
• Interior 12v/USB/battery gauge power panel 110v plugins
• Intelli Power Center with shore power 12v/110
• Integrated battery tender
• Maxx Air Fan with 4 Speeds (all weather operation)
• 4 1/2” custom memory foam queen mattress (6’7” head-to-toe)
• Rubber diamond plate floor
• 2 LED side porch lights
• LED interior lighting with dimmer
• Cargo net storage pockets
• Shelving and key hooks added to head of bead
• Blackout shade window covers
Galley Kitchen
• Pullout stainless steel sink
• Pullout stainless steel Dometic 3 burner stove
• Self-priming water pump
• Dometic 12 v/ 120 volt 45 liter Refrigerator
• Composite cabinetry with interior shelf
• LED lighting with dimmer
• Overhead LED porch light with dimmer
• Kitchen 12v/USB/battery gauge power panel 110v plugins
• Stainless steel countertop
• Paper towel holder
Dimensions
• Overall length - Tongue to Tail - 15’6” (186”)
• Overall width - Fender to Fender - 7’ (84”)
• Exterior cabin 5’W x 9’2”L x 4’H (60”W x 110”L X 48”H)
• Interior cabin (sleeping area) 4’9”W x 6’7”L x 3’9”H (57”W x 79”L x 45”H)
• Overall height with ARB awning - 6’3 ½”H (75.5”H)
• Dry weight - 1,950lbs
• Tongue weight - 230lbs
• Rated weight - 3,500lbs
• Water/propane/cargo capacity - 1,550lbs
ADD-ONS / UPGRADES
• Second ARB awing added so that both sides have awning capability
• Spare 11b propane tank and mount
• Rotopax 2 gallon Water tank
• RV Leveling Blocks
• 2 Wheel Chocks
• Battleborn 100 AH lithium battery with Victron Connect charge controller.
Tdavis8695
