**SOLD** - 2020 OEV Backcountry (Camp-X) Truck Camper in Denver, CO - $32k
Crux
The Overland Explorer Vehicle Backcountry / Camp-X is truly one of the best truck campers available.
Built to withstand tough conditions, it's both durable and incredibly lightweight at just 1,210 lbs.
This camper performs exceptionally well year-round, including in extreme winter temperatures (-17°F at 10,000 feet, and it stayed warm and cozy).
I’m the original owner, and the only reason for selling is to upgrade to another OEV camper.
2020 Camp-X 6.85 - Specifications
  • Pop-up Roof with Gas Struts Assist for Lift
  • Removable Cabin for 3-4 Seasons
  • Sleeps up to Four
  • Ext. Dimensions (Closed): 140” L x 81.5” W x 62” H / (Open): 84” H
  • Internal Dimensions (Open): 137” L x 74.5” W x 82” H
  • Constructed with Powder-Coated Aluminum Extrusions
  • OEV Composite Floor, Walls, and Roof (R-value of 8 or less)
  • Fire-Rated Insulated Four-Layer Soft Wall (R-value of 4 or less)
  • Locking Roof Support/Hinges at Both Front and Back
  • Equipped with DOT LED Lighting
  • Designed to Fit Factory 1/2, 3/4, and 1-ton Trucks
  • Dry Weight: 1210lbs (Excludes Jacks and Batteries)
  • OEV Bracket Install Kit
  • Wiring Harness for DC to DC Charging
Camper - Plumbing, Heating and Cooling
  • Truma Aquago On-Demand Hot Water
  • Truma Vario Cabin Air Heater
  • Multi Speed Roof Vent W/Roller Blind
  • 20-gal Freshwater Tank W/12v Pump and LED Backlit Tank Level Site Window
  • Sagiv Outside Shower Connection
  • Stainless Steel Sink w/Flush Mount Glass Top w/Upgraded Long Neck Faucet
  • Stainless Steel Cooktop w/Cast Grill
  • Dual 10lb propane tanks - easy to swap if you run out
Camper - Electrical
  • USB Plugs (Type A)
  • 12v Auxiliary Connection Outlet
  • Rear Porch Light
  • LED Interior Dimmable Lighting
  • Redarc Manager 30 w/display for AC, DC, and Solar inputs
  • 200w Solar Panel
  • Dot Exterior Lighting
  • Group 31 battery tray
  • New 100ah AGM battery
Camper - Other
  • Large Dometic Dual Pane Acrylic Side window with Blind and Screen
  • Screen Door
  • Entrance Door Grab Handle
  • C-shaped Dinette - Folds down into Bed 38”x77”
  • Cabinet to house porta-potti or other toilet
  • 4” Medium Density Foam Dinette Cushions w/ Marine Grade Fabric
  • 4” Combination Soft/Med Density Mattress W/Removable Padded Cover
  • High Traffic Grade Lonseal Vinyl Flooring (plus custom cut carpet)
  • Structural Powder Coated Aluminum Interior Cabinetry W/Polymer Doors and Cast Aluminum Positive Close Latches
  • Awning Mounting Brackets
  • Outside Shower Enclosure Mounting Brackets
  • Fire Extinguisher
  • Smoke, LP/Co Detectors
  • 4 Reico Manual Jacks w/2 Handles
  • 4 AnchorGuard Derringer TorkLifts tie downs ensure the camper does not move
  • Rubber horse mat to protect bottom of Camp-X
Camper - Upgrades
  • Dometic CRX65 Built-in Fridge
  • King bed extension including extra mattress section
  • Front light bar
  • Rear molle racks
  • Rear mounted folding jump steps (2)
  • Includes roof rack bars (2) on L-Track
Known Issues:
  • Minor scratches/pin-stripping on camper and camper window (see pics)
  • Rust on camper folding jump steps
  • Window shade is separating a bit in corner
  • Camper rivets worn down on front mounting location prior to rubber puck install
Crux
more photos
Crux
more photos
Nice setup! Do you have any additional details and pics the truck? Also, am I right that you have two fridges? What went in the spot where you added the Dometic fridge originally?
Crux
@robertmspeakout
This version of the Camp-X came with a built-in cabinet for the single black dometic fridge. You can also plug-in a separate fridge to one of the cig lighter plugs, which we have done occasionally when we wanted to bring more drinks/food.
I didn't have time to capture good interior pics of the truck, but will update with additional photos next week.
Truck window sticker additional options:
- Diamond Black Crystal Peral-Coat Exterior Paint
- Leather-Trimmed Bucket Seats
- Towing Technology Group
- Center High-Mount Stop Lamp w/Cargo View Camera
- Surround-View Camera System
- Trailer Reverse Guidance
- Safety Group
- Full Speed Forward Collision Warn Plus
- Adaptive Cruise Control with Stop
- Heavy-Duty Snow Plow Prep Group
- 220-Amp Alternator
- 5th Wheel / Gooseneck Towing Prep Group
- Bed Utility Group
- LED Bed Lightning
- Deployable Bed Step
- Spray-in Bedliner
- Off-Road Package
- Hill Descent Control
- Tow Hooks
- Transfer Case Skid Plate
- Laramie Level 1 Equipment Group (ventilated seats, rain sense wipers, memory for seat, radio, pedals, blind spot)
- Anti-Spin Differential Rear Axle
- Uconnect 12" inch with Navigation
Let me know if you need any more information!
Crux
more photos
Crux
Truck is pending sale.
Camper is still available - note you will need to order and install the bracket mounting kit for your truck brand/model from OEV if you want to use the torklift tie-downs.
TNielson-18
