SOLD!
In anticipation of purchasing an a larger trailer we are putting this 2020 OP4 up for sale. Trailer has approximately 4,500 miles and 6 camp trips. Tires, new in March of 2022, have just over 2000 miles on them. Trailer comes with everything that was original equipment when we purchased it, plus lots of extras. https://www.opuscamper.us
Clear AZ Title - Located in Sedona, AZ $29,000 OBO, CASH or Bank Cashiers Check.
Standard OP4 Equipment:
Tent w/ Air Beams
2 – Water Tanks (Front and Rear) 20 gallons each
Pull-Out Kitchen w/ 4 burner stove and kitchen sink w/water.
Dometic 65L 12v Refrigerator on Pull-Out tray
Dometic 16000 btu Furnace
Cassette Toilet – Never Used
Zamp Solar Connection – Must provide your own solar panel/controller
30 amp Shoreline Receptacle
EcoTemp L5 Water Heater (used once)
Galvanized steel chassis and Rock Guard
Electric brakes & Hand Brake
Trailing swing arm suspension with dual shock absorbers
Stereo System with Bluetooth connectivity
Leatherette Club lounge & Adjustable table
Polyfoam mattresses
USB, 12v and 120v* Outlets (*shore power or GEN required)
20lb Propane Tank Holder
2 x 5 gallon Gas “Jerri Can” Holders (1 is mounted, 1 will go with trailer but is not mounted as that space is currently used for mounting a small Honda generator (not included).
Lock n Roll Hitch (Vehicle side and Trailer)
Roof Rack (500# capacity per Opus)
Opus provided Hand Air Pump (in case electric pump fails) – Never used
2” rear hitch w/ extension (never used).
Bundle of Owners Manuals and instructions
When not in use, trailer is covered by heavy duty tarp (Included)
Off-Road Construction (from Website):
Aluminum Dibond Walls
Water Tight Finned Seals
Polystyrene Insulation
Pressurized Gas Springs
Water Proofed 10-ply Floor
High Strength Bonding
Powder-coated Aluminum Frame
Accessories, Upgrades and extras:
Air Canopy – Just Purchased, never used. $799 value (see photo below) Provides more coverage than the “Sun Pole Awning”. https://purplelineusa.com/product/air-canopy/
Pole Sun Awning
Rinnai Water Heater V53DeP – Adjustable for elevations up to 10,200 ft. $580 value.
https://www.rinnai.us/residential/product-detail/v53dep This is permanently mounted on roof rack in a pelican case. When rack is in vertical position (to inflate tent) the Rinnai is ready to be hooked up and used. Exterior Water and Gas hoses for use with Water Heater/Shower (included).
Note 1: It can be removed it with simple tools. (Includes a Go Power 150W Pure Sine Wave Inverter (Needed for Rinnai Electronics). Plugs into Opus 12v cigar plug.)
Note 2: The EcoTemp L5 water heater works as designed at altitudes below 5000ft., but it does not work at altitudes above 5000ft. Since we mostly camp at 7000 to 10,000 ft. altitude, we needed something that would work at those elevations. The Rinnai works great at all altitudes.
Shower Tent: Quick Pitch En Suite Shower Box/tent $500 value.
Permanently mounted on roof rack. It rotates into position when rack is vertical. http://www.quickpitchnorthamerica.com/quick-en-suite/
Note: It can be removed with simple tools if desired.
Water Pumps: 2 x Shurflo Revolution Water Pumps 4008-101-A65 – Replaced both noisy Chinese pumps.
Upgraded Exterior Shower nozzle – For Opus provided exterior shower - Original one leaked.
Extra Opus Water Hose: Use when sending Hot Water to Kitchen area.
Tires (& Spare): Purchased / Installed 3/8/22: Upgraded to Falken Wildpeak A/T3W - LT235/75R15 Load Range E(Standard tires were Goodride load range C). The “C range” tires were “maxed out” when trailer was loaded and full of water. I was concerned about a sidewall blowout.
Water Filter: Inline RV water filter for filling tanks (Replaced 3/22, never used)
Potable Water Hose: 15’ potable water hose for filling tanks
Thermostat: Replaced Dometic Furnace thermostat with digital version.
Switch For CO2 Sensor: This prevents CO2 monitor from alarming (beeping) when trailer is “folded up” for travel.
Extra 12v LED lights: Made to plug into Opus 12v receptacles.
Bag of Misc. “Extra” Parts: Gaskets, O-Rings, Clamps, Fuses, etc..
12v Fan
Aluminum Ladder (5’ 7”)
Box of Wood Blocks: for stabilizers
Extra Wheel Bearings and Seals.
Tent w/ Air Beams
Polyfoam mattresses
Pole Sun Awning
12v Fan
