Expedition model full of upgrades. T3 package plus some additional things. Garage kept and only been on soil and gravel roads, no rough off-roading- same could be said for the previous owner. We've only taken it on 6 close trips. It has the following: Icon suspension, hot dipped galvanized frame with urethane coating, max coupler hitch, 7 pin connector, electric brakes with brake away switch, 2000 watt inverter, shore power battery charger, dual AGM batteries, zamp solar controller, 90 watt zamp solar panels, Redarc DC/DC converter, 11lb propane tank with 5 lb spare tank, molle panels, tread plate on box tops, rod storage, Dometic hot water heater, 42 gallon food grade and BPA free water tank, refrigerator slide with 59 qt. Snomaster fridge/freezer, 23 Zero Walkabout tent with annex, 23 Zero 270 degree Peregrine awning with complete side walls ( I've attached some stock pictures of what the annex and side walls look like), kitchen with birch wooden slide out drawers, dual burner 10,000 btu Partner stove, sink, swing out privacy shower, 5' water hose with shower head, 265/75/R16 BFG All Terrain Ko2 tires. Clean title in hand. Only issue is cosmetic where the previous owner must have gotten it a little warm under the RTT section that hangs out. It wrinkled the hard outer layer underneath the overhang a little bit in one spot but doesn't hurt the function. I plan on adding a picture of that as soon as I can. Paul 828-460-0270
23ZERO_270°_Left_Peregrine_wing_Awning_1500x1500-S1-E1-1.png5 MB · Views: 116
Peregine-270USP-Overhead-with-walls-1-of-1_194b092e-80e9-4852-a5e3-30f7b45b1ec1.jpg142.7 KB · Views: 118
