High Water
Baja Bliss
SOLD
For Sale: 2022 Rover Off Road Custom Built Toy Hauler Trailer
Price: Was $75,000. Reduced to $59,000. Reasonable offers will be considered.
Google Drive for all photos and videos: https://drive.google.com/drive/folders/1Qo-icHm8tzGcbFFaSIDg5x6Zth5zs_cC?usp=sharing
We put a great deal of effort in finding a commercially available toy hauler trailer that met our specific requirements for a winter of fun exploring in Baja California South, Mexico: A garage large enough to hold two motorcycles plus gear, overall length less than 26’, living space separate from the garage, abundant solar and lithium batteries, 12v-to-120v inverter, 120v mini split air conditioning and diesel heat, and most importantly, QUALITY construction.
We could not find a toy hauler that met our requirements, so we designed our own. Then we found the perfect company to commission the custom design build. This custom-built toy hauler was built by Rover Off Road, a division of Charmac Trailers, in Twin Falls, ID. The trailer was completed by a very competent team in July 2022 and we have been very happy with the construction quality, design and found the systems functionality have been flawless. We have just spent the past winter in Baja California exploring the trails on our motorcycles using the trailer as a basecamp. The boondocking self-sufficiency of this trailer worked perfectly. The all-aluminum insulated structure is light weight, very durable, and no rust or water damage can occur. The only reason we are selling this is due to a change of travel style for us.
Garage
The garage contains most of the mechanical system for the trailer’s self-sufficiency. The minimum required garage dimensions were the starting point of the entire trailer layout. The garage floor is behind the rear axle, so it is dropped 7” below the structural frame rails. The garage can be used for an assortment of toys beyond motorcycles including mountain bikes, a quad, inflatable SUP/Kayaks. Check the dimensions below to determine if your favorite toys will fit.
Wall dimensions: length 8’10” x width: 7’4”
Floor to ceiling: 5’7”
Flat floor dimensions: length 8’ x width 5’4”
Garage opening height: 5’3”
Water Systems
Gray water: 35 gal
Fresh water: 60 gal
Black water: None, separating composting toilet, more information in the “Wet Bath” section
Water filtration: Three stage system. 5 micron + 1 micron + 12v UV light for whole house potable water. With an easy switch of ball valves, the water going into the tank can be run through the filtration system for double filtration and UV.
Water distribution: Sink, indoor shower, outdoor shower
Water tank can be filled via a pressurized connection or a gravity fill.
Hot water: Elwell Timberline hydronic diesel fueled hot air and endless hot water combo LINK
Air Conditioning & Heating
Mini split high efficiency air conditioner heat pump, Mitsubishi Electric Trane model NTXSMT12A111AA. 18 SEER, 10 HSPF efficiency, Inverter-driven compressor maximizes energy savings by using only the energy needed to perfectly cool or heat. LINK
Hot water and hot air: Elwell Timberline hydronic diesel fueled hot air and endless hot water combo. The garage is also heated to protect the batteries from freezing temperatures. LINK
Electrical
1200 watts solar generation via 12 Renogy 100 watt panels LINK
600 Amp hours Lithium (LiFePo) via 6 x 100 amp hour Expion360 batteries LINK
Victron Multiplus 3000 120v inverter and shore power charger LINK
Victron Cerbo GX multi-input controller LINK
Victron GX Touch 50 color LCD display LINK
Victron Smart Shunt LINK
Victron Solar Charge Controller MPPT 150 I 85 LINK
Victron system monitoring via VictronConnect Bluetooth app
Manual battery disconnect switch
30-amp shore power connection. The 30 amp can be adapted to a 20-amp and the current limited via the Victron controls. This is very handy in many low-power situations.
LED lighting throughout the trailer
LED flood lights, front rear, and side
Multiple 120v and USB sockets
Kitchen/Dinette
Passenger side galley across from the 4-seat dinette
Sink: Dometic VA8000 square sink with glass cover LINK
Cooktop: True Induction double burner cook top LINK
Fridge-Freezer: Dometic 120v AC or 12/24v DC compressor fridge CRX110 LINK
Storage: Custom-built cabinets are welded and painted aluminum framed with simulated bamboo laminate doors and full-length piano hinges with Southco latches and adjustable shelves.
Windows: EuroVision double acrylic with screens and blackout blinds, distributed by Tern Overland as Arctic Tern brand LINK
Countertop and Tabletop: Maple butcher block
Wet Bath
Shower: Thermostatically controlled so no blast of hot or cold water. The spacious shower is the best we have had in any RV.
Toilet: Separating toilet is a C-head with a 12v continuous vent fan. The trailer can be sold with or without the toilet. It is very easy to remove and install a unit of your choice.
Ventilation: Dometic FanTastic Vent Fan 7350, remote control, reversing, rain sensor LINK
Sleeping Area
Queen size mattress with side cabinets (side cabinets are easily removable if a king size mattress is desired)
Bed area height clearance = 35”
Ventilation: Dometic FanTastic Vent Fan 1250, 3 speed manual controlled, reversible LINK
Trailer Dimensions & Weights
Length 25’ 5” (305”) = box length 20’ 6’ + tongue 4’ 11”
Width 7’6” (90”)
Height: 10’ 7” (127”) to the highest point which is the top of the roof access ladder
Trailer Weight: 6700 lbs (empty, no water, full diesel)
GVWR: 10,400lbs
Tires: LT 245/75R16 BF Goodrich A/T All Terrain KO2 Load Range E
Wheels: Ultra Wheel Company black powder coated.
Two spare tires and wheels included
Axles (2): Each axle is Dexter 5200lbs 6 lug with electronic brakes
Exterior Key Features
The awning is a Dragon Fly Tarp LINK and can be deployed on either side. We have had many standard RV awning failures and elected to use the Dragon Fly this time. We have absolutely no regrets and would use this on all future travel-vehicle builds. It takes about 5 minutes to set up and can endure severe winds with no issue.
There is a fixed-mounted flip-up table and 120v outlet on the passenger side rear of the trailer. This is very convenient for outdoor cooking and a stout workbench.
The rigid aluminum fixed ladder offers safe access to the fully walk-on roof.
The outdoor shower is very handy on beach days.
By design, the exterior has no easy-to-break-into storage hatches. All storage and mechanical systems are accessed from the interior.
For more information, or to set up a showing, please contact us at:
Instagram: @FloodExploration
Facebook: Flood Exploration
Email: FloodExploration@gmail.com
Garage
Water Systems
Gray water: 35 gal
Fresh water: 60 gal
Electrical
Kitchen/Dinette
Wet Bath
Sleeping Area
Width 7’6” (90”)
GVWR: 10,400lbs
