ROA-OFFROAD
Supporting Sponsor / Approved Vendor
FOR SALE: 2022 Xpedition trailers Voyager Teardrop 16
Updated Price: $39,997!
Description
Super clean Xpedition Voyager loaded with options for sale! Ready to roll! The only thing it doesn't have is a fridge!
iKamper X-Cover with annex, awning, winter insulation kit, upgraded mattress
2,000 watt inverter
2x Lithium Battle Born Batteries
Redarc management system
23zero shower enclosure
10" Brooklyn bedding memory foam full XL mattress
270 degree awning
Some Specs-
Gross Weight Rating : 4200lbs
Base Trailer Dry Weight: 2600lbs
Overall Length: 192”
Overall Width: 89”
Overall Height: 82”
Ground Clearance: 18”
Track Width: 76”
Suspension Travel 4.5"
Interior Length: 86.5”
Interior Width: 55.5"
Interior Height: 48"
Mattress Size: 53” X 75"-80”
Freshwater Capacity: 36gal
Roof Rack: 94” X 58"
All metal construction, no wood to rot or mold.
Aircraft grade engineering with 99% of components manufactured from aluminum. Apart from the tongue, suspension, and bumper/hitch (which are steel) the Voyager trailer is manufactured entirely of aluminum and stainless steel. This gives you the benefit of higher strength, light weight, and fantastic corrosion resistance.
1/8” Aluminum Exterior shell construction including roof
¼” Aluminum Base Plate
All joints are secured by ultra-high strength mechanical fasteners using special tooling capable of ensuring a proper connection 100% of the time.
In-house engineered & manufactured Independent A-Arm X-Ride Suspension (2023 Model)
Extreme off-road jack
360 degree Maxcoupler Hitch (Receiver and Tow Vehicle Adapter)
Dual Side doors with operating windows and screens (26” X 36”)
2 3/16” insulated walls
Roof rack with 6 cross rails (94" X 58")
Extruded Polystyrene Rigid Foam Insulation that is moisture resistant and boasts the following certifications
ROA OFFROAD SC - Dunc SC - Call or Text - (801) 860-0035
Description
2,000 watt inverter
270 degree awning
Some Specs-
Overall Width: 89”
Overall Height: 82”
Track Width: 76”
