SOLD - 2023 Jeep Gladiator Rubicon, AluCab Canopy Camper, fully custom interior
cug
Jeep Gladiator
2023 Jeep Gladiator Rubicon EcoDiesel, purchased in spring 2023
• ~ 23k miles
• All services done, upcoming one will get done as well
• Located in Las Vegas, Nevada
• Clean title
This is the perfect overlanding, hunting, or travel rig to go off the beaten path.
See photos and video below!
SOLD!
Please note that some of the photos show accessories we have taken off for the sale (e.g. Maxtrax boards, phone holders, shovel, pillows)
There have been no permanent modifications made to the truck, everything can be taken off. Other than maybe the Hot Head Headliner, since this is glued on the plastic roof panels. No cuts in the load bed or the car body.
The full build is documented here:
Video Walk Through:
Jeep Mods
  • 3" Terraflex Suspension with Falcon adjustable dampers
  • Terraflex steering damper
  • LED Headlights
  • Bolt Hood Lock, keyed to Jeep key
  • Locking Gas Cap, keyed to Jeep key
  • Trailrax Roof Rack, with brackets to mount Maxtrax recovery boards (boards and mounting pins not included)
  • RakBlokz Mud Flaps
  • RAM Mount Tough Track
  • Hot Heads Headliner with noise dampening underneath
  • Re-mounted the backup camera to 813 Design filler panel
  • OEM Wheels and Tires (33" Falken MT-01)
  • Anvil Overland accessory mounting rail with mounts for RAM mount cradles (cradles not included)
  • Storage net under roof for soft clothing, hats etc
  • Epic Kraken Dual Piston ARB Compressor under passenger seat, air outlets on both sides
  • Midland Radio MXT275VP4 already mounted (never used)
  • Extra fuse block in car cabin, power provided by camper house battery for fridge
  • Rear seats and tailgate will be included in the sale
Custom rear seat delete
  • 2/3 and 1/3 platforms, should be able to install separately, we have them connected but I designed them to work either way
  • 80/20 and Baltic Birch construction, Osmo coated
  • Marine / Automative carpet
  • L-track rails for fridge and for securing other load
  • Fully supported underneath, no bending, etc
  • Follows the curves of the Jeep perfectly
  • Rear wall covered in carpet, some noise insulation underneath
  • Storage underneath, full width
  • Storage on top, we had two Frontrunner Wolfpacks, two Wolfpack Small, and one Zarges box in there on trips
  • Dometic CFX3 55IM fridge with Ice Maker
  • Installed and dust sealed by TinyRig
  • Rear door switched so it opens the other way around (away from traffic)
  • AluCab 270 degree awning mounted on passenger side
  • AluCab Shower Cube on driver side
  • Rhinorack Mount Rails on rear door
  • Rear Molle Panel on driver side
  • 140W Solar Panel on Top (Sunflare)
  • GP Factor rear door table on custom back plate
  • Door insulated with Thinsulate and custom made panels
  • Bed with AluCab mattress (Froli system not included, happy to send you a link if you like it)
Fully Custom Interior Build (see photos and video)
  • 80/20 and marine grade Baltic Birch furniture, Osmo coated for natural look
  • 12mm base plate on top of some inulation, covered with marine / automotive carpet, protected by aluminum edge piece
  • Suitable for two people to sit inside when the tent is up
  • Webasto Diesel Heater (2kW), routed to two separate warm air outlets (one towards water tank, one at feet height near rear door)
  • 12V Travel Oven
  • Space for a toilet (e.g. Trelino), toilet not included, need to adjust the mounting to specific toilet
  • Dedicated space for two Frontrunner folding chairs (chairs not included, but could talk about it)
  • All original Southco latches
  • Mosquito netting where it makes sense, extra fine mesh, not the heavy AluCab canvas combination, but custom made pieces
  • All metric construction, just like the truck itself
  • All designed and then custom made by my wife and me (see build thread)
Electrical
  • 2x 100Ah Batteries (Renogy)
  • Redarc Redvision 80 and Manager 30
  • GP Factor mounting for the above
  • Redvision Display relocated to rear door
  • Redarc BCDC 25, additional charger + hookup for a solar blanket (Anderson Plug)
  • Switchable alternator charging: none, 30amp, 25amp, 30 + 25amp
  • Shore power via Manager 30, cable under bench, not routed to outside
  • 2000W Redarc Inverter, routed to outlet next to rear door for induction cooking
  • Induction plate included
  • 900W electrical kettle included
  • BlueSea Switches on passenger side for travel oven, water pump, Webasto
  • Switch for toilet vent (toilet and fan not included)
Water
  • 50L AluCab water tank, Thinsulate insulation behind it
  • 12V Waterpump with strainer
  • GuzzleH20 Filter system with charcoal and UV filter
  • Sink with faucet
  • 1.75 Gallon grey water tank (Rotopax)
  • Extra quick connect outlet for Queen Size Camper shower head
  • Queen Size Camper Shower head
  • All paths can be closed off via valves
Space for Frontrunner Chairs
cug
So, to answer a few of the questions I've received here and on other forums:
  • Traveling with a dog:
    • A small(ish) dog is probably okay with you in the camper, maybe up to the size and agility of a border collie. I would not recommend using this rig with a larger dog, since the interior is small. Check the video regarding the furniture etc.
  • Traveling in very cold conditions:
    • We have not cold-proofed the water system. So, as long as the diesel heater can be used during really cold times, you should be fine, otherwise the water system needs to be properly emptied and the batteries might need some warm air. They are self heating and the charging will shut off to prevent damage, but other than that, it just needs some planning.
  • Yes, rear seat and tailgate are available and part of the sale.
Regarding price:
I feel that the price is very fair, but still, feel free to send me a reasonably offer.
oskarf150
