FiremanDave
FOR SALE
2024 Bigfoot 15C8.2SB $43,900
We both agreed that we need more room so we purchased a Class C and are selling our camper. It has been well cared for and is in excellent condition. Everything works as it should, no leaks, and all service has been completed on schedule. Service records and manuals are included. Clean title in hand. Original owner.
Bigfoot makes a true 4-season two-piece fiberglass construction camper with quality craftsmanship throughout.
Bigfoot 15C8.2SB features, options and specs:
Mods: Includes a second dinette table (not installed) that converts the u-shaped dinette to a booth dinette with permanent table (i.e. no dinette bed conversion). Added a small shelf to the bathroom medicine cabinet. Added steps made from a 4-step Little Giant Safety Step that is offset to one side to allow towing and removed swing-out entry assist handle, original new steps and handle are included. Added mount for Little Giant entry steps on ladder. Added a hook by the front door for keys. Added hooks in the bathroom for hanging wet gear/towels. Added straps to hold fridge/freezer doors closed, the latches still work but they sometimes open on rough roads. Added an exterior vent cover to the Maxxair Fan in the bathroom. Replaced the lead acid battery with a SOK 12V 206Ah Lithium Iron Phosphate battery with Bluetooth. Added a paper towel rack and garbage bin. Modified the existing range hood fan vent so it can be opened and closed from within the camper. Replaced the original thermostat with a Honeywell Pro 1000 digital thermostat, original thermostat is included and can be reinstalled. Added AcuRite Digital Refrigerator/Freezer Thermometers with digital display. Added Beech Lane 12V Refrigerator Fin Fan. Added temperature monitors in the overhead bunk and exterior LPG compartment with digital display. Added Sylvox 22” Smart RV 12V TV w/ DVD and remote. Added GasStop Automatic Shut-Offs Safety Devices to both LPG cylinders. Added Reflectics thermal window and escape hatch covers for added insulation and black-out. Off-vehicle 4x4 and plywood storage platform w/ jack stands included. Fast Gun Tiedowns and mounts included with locks. I have a second larger fixed table with mount for the camper that converts the dinette into a booth (see pic).
Dry weight 2061 lbs, Wet weight 3048 lbs, Floor length 98”, Interior height 77”, Exterior height 10’ 11” (on truck), Cabover interior height 36”, Overall length 15' 1". Tank capacities: Fresh 32 gal, Grey 11 gal, Black 14 gal, 12-Volt Demand Water Pump System, Enclosed insulated heated tanks, water lines and slice valves, Black tank flush, Water Heater By-Pass System, RV Antifreeze Pickup System, Two 20 lb/5 Gal LPG cylinders with Auto-Changeover Valve, Ladder and roof rack on fully walkable one piece seamless fiberglass roof, Wet Bath with porcelain toilet, sink, shower, towel rod and medicine cabinet with mirrored door, Variable speed/direction MaxxAir Fan in bathroom, LED reading lights in cabover bunk, TV swivel mount for viewing from bed or dinette, cabover privacy curtain, *NEW 60’ x 74” RV Queen Serta Euro Top mattress, Wardrobe closet, Bedside Storage Cabinets, ¼” fiberglass construction with R6 high density EPS insulation, 110V/12V/USB charging ports above dinette, Coleman Mach 13,500 BTU AC, 16,000 BTU Furnace, Dometic 6 gal. Electronic Ignition Gas/Electric Hot Water Heater, Jensen AM/FM/CD/DVD/USB/Bluetooth Stereo Clock Radio, Battery Disconnect, Exterior 110V dual outlet, Cabover vent/escape hatch, LED lighting throughout, Two 200 Watt solar panels with 30 Amp solar charge controller, SeeLevel System monitor with tank levels and battery charge indicators, Happijac electric camper jacks with remote and jack pads, Radius compartment and entry doors, Radius solar reflective thermal pane windows with screens, Exterior hot/cold shower/wash station, Rear deck, Stainless steel kitchen sink with Hi-Rise sprayer faucet, Sink Cover/Cutting Board, Dometic 6 Cu Ft electric/gas refrigerator/freezer, Stainless steel oven with 3-burner range top, Tempered Smoked Glass Bi-Fold Range Cover, Range hood with fan and light, Avanti 0.7 Cu Ft 700W Microwave with turntable, Brushed Aluminum Blind in Galley, Day/Night window shades, Face framed double screwed cabinets and drawers, Laminated plywood countertops, Smoke, CO and LPG leak detectors, Fire extinguisher, Forward cab thru window, Wireless backup camera with monitor, Electrical 120-VAC/30-Amp Service, 45-Amp DC Power Converter (c/w Battery Charger), TV antenna, LED Exterior Clearance and Directional Lighting, Sewer Hose Storage Compartment, Washable Vinyl Wall Paneling, Marine Quality Fabric Headliner.
Will sell truck and camper together for the right price. 2019 Ram 2500 Laramie 4x4 6.4L Hemi, 87k miles.
