OffRoadSteph
Looking for an affordable adventure trailer RTT combo to tow your motorcycles or ATV? I need to sell my custom overlanding trailer located in Tacoma, WA. The custom rack is adjustable to three heights for loading and transporting dirt bikes with Lock n' Load chocks, or easily remove the chocks to transport an ATV or other fun stuff. It takes some strength to lift the rack or you may need to install new lift supports. New BFG All-Terrain T/A KO2 tires. All modifications professionally built/installed. I probably wouldn't do major rock crawling with this but it was perfect for off roading in Baja, and rugged first service roads. Stored in my garage. CVT Roof Top tent purchased at CVT in January 2019. Please read all the details below. Cash please. Thanks for looking!
I put about $6,600 into this set up, but I'd like an offer over $5,900.
Trailer:
• Base trailer is 5x8 Single Axle Falcon Utility Trailer.
• Lifted for high ground clearance
• New BF Goodrich All-Terrain T/A KO2 tires with less than 5,000 miles on them, plus an unused spare
• Multi-leaf spring suspension
• Fir wood decking
• 4’ Ramp gate
• Heavy duty #20 Propane tank mount welded to tongue (tank not included)
• Lockable tool box
• #2,990 GVWR/#3,500 GAWR
• Two safety chains
• Side walls are 24” 16ga Smooth Steel
• Flat 4-way electric plug
• Sealed Beam LED D.O.T lights
• 2” A–frame coupler
• Two sets of Lock n’ Load motorcycle wheel chocks (removeable)
Rack:
• Custom welded construction
• Adjustable to 3 heights
• #60 hydraulic lift supports (may need replacing depending on your strength)
• Secure pin lock
CVT Tent
• 2019 CVT Mt. Shasta Extended Stargazer Pioneer
• Refer to the CVT website for specs https://cascadiatents.com
• Clean!
• Annex with floor included
• 2+ person
• Annex channel added so you don’t have to remove cover to attach annex
• CVT professionally mounted
Trailer:
• Fir wood decking
• 4’ Ramp gate
• Lockable tool box
• Two safety chains
Rack:
• Secure pin lock
CVT Tent
• Clean!
• 2+ person
