SOLD: Alu-Cab Gen 3-R Roof Top Tent in Eastern MA - $4,000
sjl136
$4,000 - Almost brand new Alu-Cab Gen 3R Expedition roof top tent, located in Eastern, MA. Bought 6 months ago, I used it twice on my '24 LC250 before deciding to trade in the LC for a 4G Taco. Waiting on S-P X1 for the Taco, so won't be needing this RTT anymore. This is an excellent tent built to a very high quality. You can store your bedding and pillows up top along with the included ladder to make setting up camp a breeze. Takes two minutes to park and get set up to sleep. Tent includes everything a new one would, and this is the latest model. I've had three RTTs and this was far and away the best, but I decided to stop putting off my plan for a truck and a wedge camper. The mattress that came with this Alu-Cab is unused. I slept on my Hest instead.
Engineered for Durability & Performance Lightweight Aluminum Frame – Rigid yet lightweight construction for long-lasting durability. Hard-Shell Design – Aerodynamically streamlined for reduced wind resistance, with integrated storage capabilities for gear like kayaks and solar panels. Premium Fabric – Double-layer 400gsm canvas with a hydrostatic head rating exceeding 1000mm, ensuring exceptional water resistance. Gas-Strut Assisted Pop-Up Mechanism – Quick and hassle-free setup in seconds. Full-Length Cargo Rails – Rated for up to 110 lb (50 kg), perfect for securing additional gear, load bars, or solar panels. Pre-Wired for Solar – A solar input on the roof is pre-wired to the base of the tent through Anderson SB50 plugs for seamless power integration. Unmatched Interior Comfort 70mm High-Density Foam Mattress – Ergonomically designed for superior sleep support, with a zip-off cover for easy cleaning. Advanced Insulation – High-density closed-cell foam insulation on both top and bottom ensures thermal efficiency in all seasons. Optimized Ventilation – Integrated pressure vent and 3D breathable under-mattress mesh to reduce condensation. Three-Point Access – Single-zip windows with solid and mesh panels for easy entry, ventilation, and insect protection. Zippable Rear Rain Fly – Provides additional weather protection and shade. Built for Convenience Integrated USB & Type-C Power Ports – Stay connected with built-in charging points for your devices. Internal LED Lighting – Illuminate your space with efficient, built-in lighting. Quick-Release Telescopic Ladder – Custom-designed with wide, angled rungs for easy climbing, stowing neatly inside the tent when not in use. Internal Storage Pockets – Keep essentials organized and within reach. Included Rain Cover – Standard for extra weatherproofing. All Essential Accessories Included Telescoping ladder with storage bag Tent mounting brackets Side rain fly for left or right side
sjl136
What is the weight capacity of this unit ?
Weight capacity for carrying on top of the tent, or people and things inside the tent? As for up top, the Tent Rooftop Load Rating is 110.2 pounds (50 kg) on the tent roof cargo rails. I do not have the load bars that mount to the tent roof cargo rails, so you would need to add a set of bars to carry a load on top of the tent. As for the weight capacity of the tent itself, Alu-Cab lists it as two adults. I can't seem to find a specific number but could ask if that is what you are looking for.
dhuss
