SOLD ARB Portable Compressor - CKMTP12
zonker
Fantastic ARB compressor in a bag.. 'er I mean case that is akin to a Pelican. Will inflate a 35" tire from flat to 40psi in 1 minute and change. Will run an impact gun. Easily reseat a bead. I have used it for those things listed. The power cable has been modified with an SMH / Anderson type connector. I had a setup with the mate to the compressor connector mounted on my ARB bumper so all I had to do was plug into the connector and not even open the hood. Also a set of really heavy duty clamps with the same connector so the compressor could be used in a conventional manner. Included is an extra unused connector should you want to go the same route with a remote connection to the battery. I swapped out the air chuck as I found the OEM not as friendly as conventional chuck.
Compressor is fully complete as when purchased and is in great shape and was never ever used heavily.
$700 Shipping at cost.
greatwhite24
