SOLD: AT Combo Slide
CDRJK350
For sale: $500 (New $799), pick up only.
Located: Austin, TX
Used for one year
Excellent condition
The lower slide is built to hold the JK Partner Steel Stove, and the upper slide to hold an Engel 45, a National Luna Weekender Fridge, or a ARB 50 qt . For easy of fitting a mounting plate is used to secure the fridge to the slide, it can also be bolted directly to it.
A Partner Steel Stove has been made specifically to fit the combo slide and has the controls built into the end of the unit.
This is a two level fridge slide. The Upper slide for a fridge, the lower slide for a partner steel stove (not included). The slides are rated at 500 lb rated and lock in and out. If a stove is not fitted to the lower slide it can be used as a storage shelf.
The Combo Slide is:
29"(737mm) long without the stove
16"(406mm) wide and 5"(127mm) tall.
MDH33
Why are you selling? looks like a really functional unit.
Also would be interested if you were willing to ship it.
CDRJK350
I sold it a few months ago, however I do have a Front Runner Cargo Slide / Fridge Slide for sale ($200) local pick up only, Austin, TX ...PM if you want more information (pics). Fridge slide designed to fit various fridge sizes ranging from 40l to 52l in capacity and can be mounted on top of a Front Runner Drawer System or the load bed of your pick-up. Product Dimensions: 793mm (31.2") L x 535mm (21.1") W x 85mm (3.3") H
JSKepler
