Sold . AT Overland Chaser Trailer
v8turbo
Sold
AT Overland Trailer - Chaser model. Located in South Denver. $10,200
Message me here or v8turbo@yahoo.com Mark
Jeep and Toyota hubs and wheels included
LIke new condition. Tows great. Minor dings etc. Awning has crack on front housing(see pic) does not affect use. Extreme Outback Magnum Compressor is 100% duty cycle and can run for days on end. I have several of these - this one has been used one time.
If you need any specific pictures - let me know
Links to factory site for all specs and options/pricing and review are below.
Review
AT Overland Chaser Site
Upgrades -
19 Gal Water Tank with hand pump
2 New never used Green fuel cans
Nose storage box
Max Coupler Hitch - Zerk Fitting
6 KC Led rock lights - controlled by an APP
New Custom Table - fits on fender
FIAMMA F35PRO awning, brackets, double extensions
Electric Brakes with brake away system
Roof Rack with adjustable tracks
Howling Moon Roof Top Tent - 1.6 Deluxe - Like new/mattress still wrapped in plastic RTT Howling Moon
Warn power plugs for charging battery when driving
New - Deka Battery
New - Powder coated battery box
New - Guest pro charger(3YR Warranty) Charger
New - Blue Sea Fuse Block Fuse block
New - 2 Blue Sea Below Deck Panels for USB/Cig Plug, Volt Meter Blue Sea
New - Blue Sea circuit breaker
New - Blue Sea on off switch
New - Extreme Outback Magnum compressor with 100PSI blow off valve - Magnum Compressor
3 crank up stabilizers - 2 for the back corners, one fits in tongue of trailer, plus factory jack with tire. See pic for rear mount
**Both Jeep and Toyota bolt pattern hubs. Black Jeep Pattern Aluminum Wheels come with it. Think they are KMC.
315/75/16 BFG KM2 mounted on Method Race Wheels Titanium Vex rims - these are on trailer now Methods
Rubber floor mat in trailer box
New wheel bearings and Toyota pattern hubs
Suspension -
Independent trailing arm with air bags and limit straps. New factory Shocks
DOT LED Taillights
empireoverlandza
