SOLD - Cargo Box w/ Fridge Slide-Out, $100, DFW
JPsLC
$100
Overall: 32"x41"x23" (LxWxH)
Slide: 15"x27" (Interior (holds Yeti Tundra 45 50))
Box: 21"x20" (Interior)
I bought my first Land Cruiser a few years back, and this was my first purchase to help me become an Overlander. Soon after this more babies showed up, and I have yet to be more overlandish.
This box was purchased from a guy who built it for a GX, and it has been drilled to bolt into the cargo area. It only fits in the back of my Land Cruiser if one of the with both third row seats removed, so it will require modification if you want it to fit between the seats.
It is in good shape and well-built, and I would keep it if I thought I had any use for it. The slides are in good shape and lock in the closed and open position. If nothing else, buy the box and repurpose the slides.
I live and work in Lewisville, so you need to come pick it up if you're interested.
bluejeep
just a guy
might be interested (I'm in McKinney), but the width of my Jeep LJ is closer to 35" max if I remember. Would it be much to slim it down somehow? maybe take it off the enclosed box outer wall might be easiest
JPsLC
That was always my plan to make it fit. The carpet is continuous over the top of the box, so it would be easy to peel it back and trim the top and bottom (likely in place if on saw horses and the inside was braced).
WingNutLG
$100
Slide: 15"x27" (Interior (holds Yeti Tundra 45))
This box was purchased from a guy who built it for a GX, and it has been drilled to bolt into the cargo area. It only fits in the back of my Land Cruiser if one of the third row seats is removed, so it will require modification if you want it to fit between the seats.
Looks like your profile lists a 100 series - is that what this was bolted into? You mention that one of the third row seats needed to be removed, can this be installed with one third row seat deployed?
Nice setup for sure! Please put me in line if the others are interested.
JPsLC
The original post has been edited to state both third row seats must be removed to for the box. More pictures with the box installed.
bdpkauai
