SOLD - CellTech 7'x16'x7' Tall Enclosed Cargo Trailer - TX
RagnarD
2024 Cell Tech 7’x16’
7’ wide, 16’ long plus V Nose with 7’ Tall (Interior)
5200 lb Dexter spring axles. 9,990 GVWR.
Brakes on both axles. 225-75-15 LRD Tires. 6 lug wheels.
Rear barn doors with 4 hinges per door. Metal latches to hold doors open.
36" passenger side door with RV latch and pressure bar. Can operate latch and lock from inside the trailer
Interior LED lights with switch. Exterior LED lights all around. Walk on roof with E-Track.
Floor, walls, and roof are galvanized high tensile steel. Skinned inside and out so clean/smooth interior finish. Walls are similar to the walls used in semi-trailers. Vertical E-Track along both sides.
Floor crossmembers are 4” channel on 16” centers. Tongue is 6x2” rectangular tubing with adjustable coupler and drop leg jack. Entire frame is galvanized.
Galvanized steel floor with non-slip coating. No wood floor to rot and no bare steel to rust. Easy to add floor mounted tie downs/D-Rings.
Plenty of head room at 7’ tall. 7’ width is wide enough that you can use the decking bars to make a sleeping platform (sideways).
Will include brand new spare wheel with Goodyear Endurance LRE tire, 4 Aluminum decking bars, and handful of other E-track accessories. Only a few months old. Basically, a new trailer. No sales tax and you get some accessories compared to new. Can sell with pintle ring or 2 5/16” ball coupler.
I adjusted bearing pre-load and brakes on each wheel. Had all 4 tires plus the spare balanced.
Paid $15K out the door with accessories and TTL. List price for base trailer new is $12.5K.
Trailer is located in Weatherford TX. Willing to drive to meet a buyer.
Can do a phone call or facetime if you are not local and want to see more details.
Texas Title in hand.
