Sold - Colorado - Custom RTT trailer
gillbrak
Customcondition: newfuel: otherrv type: othertransmission: other
Custom built overland trailer. Built from old sailboat trailer (Plated / Tilted in CO). Priced without tent, fridge, fridge slide or solar panel.
Price $5,500.00
142”L x 70”W x 70”H (w/ RTT), 55” H (w/o RTT)
Dexter 3,500 lb axle
265/75R16 (31.6”x10.4”/16) tires with matching spare (Toyota 6 lug pattern wheels)
Pope Overland 3 person tent, very similar to Tepui Kukenam (bed dimensions 56”x96”) - Optional to add
Mounted 5 gallon military fuel can
Ammo can storage box, electrical access door behind
New battery and wiring done last summer by Off Grid Engineering
10 gallon water tank with RV style fill door, electric pump to shower head
Rear stabilizers
Max Coupler off-road hitch
Front storage rack (will fit dirt bike)
Trasharoo
Rear LED lights x 2
Axe / Shovel / Chainsaw mounting points / track on left side
Cost way 12V fridge on slide works like new - Optional to add
Custom drawer storage
Lower right drawer houses storage, cutting board / sink, butane stove
Upper right drawer can be configured however you want
Upper left pull out table, have legs to remove and use as campsite table
Lower left drawer can be configured how you want and is deeper
New Duracell AGM battery
AcoPower 105W briefcase solar with controller - Optional
Trailer has been all over and all levels of trails without any issues. Not sure of weight but can’t notice when pulling it. Coated in Raptor truck bed lining for easy touch ups. Expanding family so moving into something larger. Photos show it on trickle charger as has been sitting (covered) all winter. Meticulously cared for.
Also do you have pics of undercarriage as well?
The stove platform is 19.5”x 16.25”x 4.5”. You would be able to store the stove on it when closed as the interior is deeper but to set up at camp it would have to hang off a couple inches with how the current handle is configure. Kind of hard to explain.
You could rig up a 5lbs propane mount pretty well anywhere on the body of the trailer. The front deck is rather large if you wanted to carry a 20lbs.
Sweet I see that now, dont know how I missed that the first time. Sent you a PM with some other questions.
Thanks
Bobbyjr
