Sold:Crux 1600 For Sale (04/30/21)
Speleo
Speleo
2017 Mfg date, purchased in 03/2018.
This description, cut from another seller, aptly describes the unit, with extras added:
This 2017 Crux 1600 weighs in at only 1,800 pounds. In excellent condition, with independent suspension and articulating hitch, this unit can go anywhere your vehicle can tow it!
The Crux 1600 has an outside kitchen with a propane cook stove and sink.
The unit also has an 18 gallon water capacity. Rear slider that will fit most 50qt refrigerators. It’s incredibly capable Off-road and will go anywhere your tow vehicle can pull it. Tons of storage, in sliding lockable drawers.
This unit comes fully loaded with a huge annex room that covers the kitchen, a 100 watt folding solar panel that keeps the AGM battery charged up when you're off the grid.
Trailer dimensions: L 11’6” x W 5’5” x H 4’9”,Tongue Weight: 220lbs
Weight: 1,800lbs,GVWR: 3,300lbs
Suspension: Independent suspension with heavy duty springs and gas charged shocks
10” electric brakes with a hand brake on the draw bar, Dual drawbar safety chains
Chassis: Heavy duty, off-road, galvanized steel frame
Rims and tires: 15” alloy rims, six bolt pattern and 31” x 10.5” Cooper Tires, with matching spare.
Standard 7-pin connection plug
Water Tank: Stainless Steel 18 Gallons with alloy skid plate
Storage: All storage doors have air-tight, waterproof seals and locks
Two jerry can holders on drawbar
Four heavy duty, adjustable, lockable legs
Lights: LED lights throughout trailer, in crucial locations: chef’s galley, electrical panel, refrigeration chamber, LED tail lights
Bed Size: L7’1” x W5’7”
Electrical: 100A/H deep cycle battery, overload protection, two 110V outlets, two 12V outlets, 1000w inverter. Battery is charged by your vehicle when 7 pin style plug is connected, or solar power.
360 degree poly block coupling.
Heavy Duty Swing Up 10 inch Jockey wheel
Chef’s Galley: Slide out stainless kitchen, with two burner propane stove, sink and electric water pump.
Tent: 15oz Coated Canvas tent and ones with an additional extra large annex room.
All canvas material is 150z double stitched, waterproof, mildew resistant canvas roof and sidewalls with heavy duty Velcro and zippers. Mosquito proof and UV protected window screens with polyethylene rubberized floor in vestibule and detachable polyethylene floor in annex.
Kept inside and under cover.
Ready to load up food, water and gear, for overlanding adventures.
Extras include 4 wheel chocks, 1 leveling chock, 25ft water fill hose, 5 position USB charging station, battery pigtail connector for storage float charging, extra PVC cover. “Bearing Buddies” installed.
Deep cycle battery has always been kept on a float charge during storage.
Located Northeast Indiana
Asking 12.5k
PM for Further details.
Speleo
Speleo
Speleo
Speleo
Speleo
Price reduced. Dropping asking price to 11.5k.
This is a nice clean unit, worth considering.
Thanks,
Speleo
